Strange Zinging/Whining Noise When Starting
Aso544
Tallahassee, FL
I recently took my bronco in to have some electrical work done under the dash ( brake lights and blinkers ) . While there I had my coil replaced ( 12v internal resist). Now I notice when I start my Bronco I sometimes get a non-start with a whining /zinging noise. Even when it does start right up ( which it usually does on the first attempt) I can still her that noise for about 2-3 seconds. I assume that's the starter.
Any idea what's causing it. Starter is new with only 2k miles? Just seems strange after that work and the replaced coil that I'm now getting this noise I never noticed before.
Thanks for any help.
asinor
Tulsa, OK
It is the starter. It is either caused by the starter running after it disengages or the opposite where the flywheel is spinning the gear head on the starter, they are designed to do that, but if its overly noisy, it might not be disengaging from the flywheel properly. It might be a bearing/bushing going out somewhere in it. Might just need to be shimmed. Might just need to be tightened up. If replacing the coil caused it to start differently than before (more quickly or at a higher rpm) then it might just be noticeable now when it wasn't before.
I hate coincidences.
Did you ask your mechanic if by any chance they "fixed" or even touched anything else?
Just thinking they might have seen some kind of wiring issue and fixed it quickly without telling you about it. As a favor.
Not many shops do that type of thing of course, but you never know.
What type of starter is it? Standard EB type or the newer PMGR type?
And could they have messed with the ignition switch at all while under the dash?
Oh, and what about the wiring harness in general? Is it aftermarket?
Reason I ask is that you say you put in a new internally resisted coil. If so, that assumes you had a separate ballast resistor before and got rid of it? Maybe they didn't get rid of it?
Or, if the stock system, then that could be the wrong coil, due to the stock resistor wire.
Just wondering.
roundhouse
Did you get the starter at auto zone or advance or some other cheapie "lifetime warranty " place?
You have to she'll out the $$ for a high quality one from napa or a local place that rebuilds them on site
The starters alternators and water pumps at discount parts stores are usually poor quality
