Stressed leather
Grey owl
Stressed leather door panels, simple inexpensive mod that looks good.
davisjstone
BroncoNewbie
San Diego, CA
Did you use a foam backer or anything besides the leather or vinyl? Been wanting to do this myself so any pointers are welcomed. 👍
fordguy
What panels did you use and where did you get the leather? Looks good, clean and simple. Made my own panels and padded, they turned out ok ish.
Grey owl
Grey owl
Those turned out great, look terrifjc
Grey owl
Grey owl
No i didn't use any foam, just use a good quality contact cement, don't over stretch the material. After you get the material on take an awl and make your screw holes.
fordguy
I used marine vinyl, it doesn’t like heat. The leather can be manipulated more than the vinyl.
ntsqd
heratic car camper
Upper SoKA
The advice an upholsterer gave me was to use DAP Weldwood Contact Cement for this sort of use. And that one of those rollers commonly sold to lay down dynamat et. al. is really good for getting the covering to lay flat.
I've yet to use either, but I expect to in the next 6 months or so.
.94 OR
Willamette Valley, OR
This stuff works great on a lot of applications. Trick is to cover both sides with glue then let it tack up before applying.
We used spray on adhesive for a headliner in the Yota project and it released a while later. Tore it out and used the Weldwood contact cement. It will stay in place now.
ntsqd
heratic car camper
Upper SoKA
Headliners seem to be the worst case test of an adhesive. Super 77 won't hang, I'm told that Super 90 will but I've not tried it.
