Stretching the wheelbase... geometry?
Grunt1058
Land of Entrapment
OK... I'm getting my axles this weekend. I want to start planning my suspension. My goal is to stretch the wheelbase to make room for the 40" MEATS I want to run. Problem is, I'm not sure what's going to happen to the steering geometry when I'm done?
madness
Stretching the wheelbase is always going to make the turning radius wider, but depending on how you stretch it, shouldnt make it drive any worse, it actually should drive better on the street at least. If you move the front axle forward, you may need to look into moving the box forward with it, in which case the steering angles shouldn't be affected if done properly. You will likely need to relocate the radiator to clear the steering box if you do this depending on box and bodylift. The rear is pretty straightforward, you may need to move the rear tank though, depending on how far you go back and the tank setup you have, and also change the rear filler setup. I havent done this on mine yet, but it is one of many things I am planning. Let me know how it goes.
Grunt1058
Grunt1058
Land of Entrapment
madness, sounds like what I was thinking already. Move the PS box forward with the axle. And making a custom rear tank to clear the pumpkin in the back. Haven't started measuring yet. Waiting to get my axles in place before I do. But, will let you know as soon as I find out.
TN1776
Depending on how much you push it - If you find the PS box that everybody converts to 4x4x2, but leave the original internals intact, you can run it with the pitman arm facing forward. Should be an easy enough box to find.
onebadd73
Moreno Valley, Ca.
I moved my rear axle 6" back. I had to cutout the rear crossmember and fab up a new one which I moved back 4". My tank is at the end of the frame rails. I'm in the middle of moving my front axle 4". I had to cut out my coil buckets and trac bar mount. I have the 4x4x2 box and plan on running the pitman arm facing forward. I might have to cut out the front cross member and relocate it up so the drag link doesn't hit it. Im running 37" tires.
carter2772
Camano Island, Wa
I moved my front 4", and didn't have to move the front x member.
NGABronco
Always Learning
N. GA now South Carolina
Just cut it in half, lengthen the frame and all ya got to do is replace some sheet metal!!!;D ;D and lengthen the drive shaft, brake lines, gas lines, e-brake cable,etc,etc,!!!;D ;D
NGABronco
Always Learning
Hey Steve, that was one sweet rig, but he was hauling a family of 5!!! I'm just doing an extended cab for me and the lady friend. I remember the ooooh's when he drove up at Duff's. He was behind me at the park at the BD SC last year and I crawled all over/under that rig!!!! He did it right!!;D ;D
Snafu
Guntersville, AL
I think with 40" meats you are gonna want full hydro steering, especially if you plan on doing any real wheeling. If you go full hydro you don't have to worry about relocating the PS box. Bite the bullet and shell out the $$$$ now, because you know you will a year from now anyway. Good luck sounds like it will be sweet rig however you do it.
