Stretching the wheelbase
clayne
My Bronco at 114 and fuel cell in back. I think moved front 8" and back 14" with both ends 4links. Don't look worth a Damn but Hell in those Rocks.
RFR2212
Chicago Burbs
How far can I stretch the wheel base on my 72 bronco without it looking ridiculous? I'm going to add a doubler so I need to stretch the rear out as far as possible. I already moved it back 4". How much father can i go? Pics appreciated !;D
I'm in the same boat. I could shorten the shaft 6.75in but if there's 7in of frame available to move it back, I'll just stretch the rear.
Looks like I'll need to get some sheet metal to work the wheel wells first.
Silverhorse
Silverhorse
Pensacola
Thanks for all the great pics guys, I plan to do a 4 link and stretch the wheelbase to around 107 or so. That should help the driveshaft once the doubler is added. Any recommendations on the 4 link? All new to me.
SC74
I moved my rear back 12" and went with a RCI fuel cell. I've gotta go with 2" body lift to clear it now, but did not lose any bed space this way.
You can see the rear x-member has not been done, but what I plan on doing is a raised "hoop" tube over the rear axle truss.
Tito
CB Fire Starter
Bakersfield, CA
What is the part # on that tank and its capacity, that looks like a real nice fit. I am contemplating putting one in front of the crossmember from behind the yoke to a more forward mounted crossmember and then run a winch between the tramerails in the rear with no overhang.
SC74
It's a RCI 1160S 16 gallon capacity.
It says 23" wide, but it's more like 23.5" - since it's poly it's not square at all. It has to be put in from the bottom up to fit - can't slip it all the way through the rails - it's a TIGHT fit!
SC74
Tito - If I had to do it all over again, I think I would stretch the frame like yours is. The body work has still been pretty extensive for me and I'm afraid that I'm still going to end up losing my rear corners or having to dob the rear to allow room enough for the tires.
bronko69er
EB Addict
Renton, WA
Some reconisance photos from Katemcy......
Silverhorse
Silverhorse
Pensacola
Hey, Those 4 link bars look familiar! Wish I had some.
744x4
Taylors,SC
well if Jack would get off his ass and make some more everyone could have some.Those are the prototype set but they are installed on a D-60.I stretched my buggy frame 12 in in the center right at the flat part behind the t-case but I dont have a body.Karl Bradleys is stretched in the center like my buggy but his frame is a custom made piece as where I just used stock EB frame rails and then sleaved them with 188 wall stock and butt and plug welded the hell out of it.
Silverhorse
Silverhorse
Pensacola
yes, Stretch it. I'm going to move it about 12", so I'll be doing some serious sheet metal work. Luckily mine is very rusty so I don't worry about screwing anything up!!
Silverhorse
Silverhorse
Pensacola
Hey Keith, That you?
Silverhorse
Silverhorse
Pensacola
I too would like to see some pics. I'm in the process (still measuring/ figuring cost) of stretching one 13", I figure that I can use the before and aft sections of a quarter panel and retain the stock uncut wheel openings. I want to gain room behind the rear seat for two dogs.
Makes sense to me. Post up some pics when you get started.;D
Madgyver
Bronco Madman
4 link rear, Cage arms front, 2nd gen Bronco steering box unmodded, FW axles...X-members will be cut for clearance........ No pics yet..%)
carter2772
Camano Island, Wa
My 68 i am building right now, i stretched the front 4" in the front and 4" in the rear. Makes it a 100" wb. Also the rear is a James Duff 4 link. Would post picks but cant yet. It is just frame and suspension right now. Motor, trans, t case going in next week, waiting for the rebuilds to be done.
Also i have spoken with this guy, see link, and he has done the same as i. But his is custom built 4 link rear w/ coil overs all around.
http://www.youtube.com/user/4wheeldrivebronco
