Stubborn bolts
Tulsa76bronco
Any suggestions on how to get the two square nuts off the rear tail gate Handle plate. I have tried using PB blaster just can't get them to budge
broncnaz
They are tack welded to the plate you would have to grind them off.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Are you trying to remove the plate? If so, you need to unbolt the two bolts on the other side of the tailgate. They bolt into the nuts on the handle from the inside. Stick your head over the tailgate, and they are easy to spot on the other side of the handle.
Tulsa76bronco
Tulsa76bronco
Broncnaz thanks no wonder I couldn't get them to budge I don't want to destroy them as I am not getting a new one just going powder coat the one I have. I thought about the bolts on other side but PO line-x tail gate including the bolts
