Stubborn D20
badandy73
Broncoholic
Pulled my C4/D20 out yesterday to begin a 4R70W swap.
Can't get the transfer case to separate from the back of the adapter (yes, all 6 bolts are out). It should come off without having to do anything else or pulling the adapter off the back of the trans first, correct?
Is there a trick here, or do I just need to get a bigger dead blow?
tbratz
Sometimes they can be very stubborn to separate. I remember trying to separate mine a while back and I finally resorted to using a large hammer and block of wood hitting it at different locations until it finally came lose. Once there was a small gap between the t/c and housing I then used a small pry bar to pop them apart.
Be careful and try to avoid prying, it is a sealing surface. Unless you don't mind leaks.
