Upper and lower 5.0 intakes - 100 obo
Dana 30 missing one knuckle w/stock carrier and gears(no axles)
Dana 30 knuckle to knuckle, no axles(Ox installed but will br removed)100 for both
Dana 30 carrier w/ 3.50 gears and diff cover - 45
Dana 30 4.56 ring gear and pinion - 50
1 short inner 2 long inner axles(no stub shafts) - 25 and 30
Dana 44 carrier w/ 3.50 ring and pinion
9" spider gears 5
Fender well jack hold down arm - 5
2 JD 70/30 auto adjust shocks - 20
4 blue shock boots - 10
High Lift Jack black cover - 10
2 Spicer 5-260x u-joints -30 for both
1 car quest greasable u-joint 1-5800 - 15
Emergency brake cable(pass. side) - 10
Single groove crank pulley(stock) - 10
V8 Intermediate housing - 20
2 Bronco emblems - 15 ea.
1 302 emblem - 10
Brake light bezel, housing, and lens(dash) - 5
Rear seat w/ armrest - 35
2- 3 speed trannys 1 is a HEF - 75 each
3 Speed shift linkages - 10
stock air cleaner - 25
Dana 20 shift lever - 5
Dana 20 T handle - 10
Front side marker lights w/gasket - 10
Rear red marker lights w/ gaskets - 10
Manual steering box w/pitman arm - 25
Dash cracked - 20
2 factory ps pumps w/ brackets - 15 ea
Aux. fuel tank and skid plate w/ filler neck(has been patched) - 50
Rear gas tank to frame brackets - 10
Steering stabilizer brackets - 5
Electric wiper motor - 25
Wiper motor drop bracket - 10
Wiper arm assembly w/ wiring - 15
stock windshield washer fluid pump - 10
Kayline soft doors w/ metal frames and all hardware - 200
Kayline soft top w/ all hardware - 300(pm me for details)
2 front brake hubs - 15 ea.
2 drum backing plates - 10 ea.
2 spindles - 10 ea.
9" spider gears 5
1 302 emblem - 10
Dash cracked - 20
2 spindles - 10 ea.
