    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
WA Updated! More stuff! Moving Sale
Status
Not open for further replies.
Hozr
Rogue Valley, OR
Moving soon and not taking everything!
Added 12-3
Accelerator pedal $5
Scott Drake Stainless Door Strap Kit $20
Wild Horses Door Hinge Rebuild Kit $20
Kiser Riser Pics added below
Update 12-2 - Please PM me if you want something or I will most likely miss it!
Vintage air parts pics added
Adding:
WH 4.5 Rock Cralwer Coils - Black - Excellent shape $100
OEM Trac Bar with good bushings $45
Sold: Heads and cam include Timing chain set and lifters as well!
Original Post:
Sold: Complete Explorer Serpentine setup with harmonic balance and crank pulley, tensioner, alternator and bracket, remote reservoir power steering and bracket, A/C compressor, clutch fan, belt. $300
Sold: Custom Chrome/white gauge cluster by ClassyChassis - $300
Holley Truck avenger 670 (electric choke), Misc Holley carb parts/spares $300
OEM 289 cast iron exhaust manifolds (pair) The PN's of the manifolds are D10E-9430-CB and D1AE-9431-BB $75
Sold OEM bronco 289 oil pan with Lokar flexible dipstick $75
OEM 28oz flywheel, starter, LUK clutch assembly $100
Sold: Wild Horses V8 fan shroud, steel, black - used with explorer clutch fan and 1" body lift. Slightly trimmed the ring for clearance. $35
Sold: Ford GT40P head swap with 15k miles on the rebuild. Includes heads and Comp cams SK31-216-2 S Kit and push rods. $150
Sold: Fiberglass Hood Scoop. Bolt on, will cover 18-19" hole. Black $45
Weld On Trac Bar Riser (Kiser Riser), used $25
Driver Air Duct Inlet Seal (Square) NIB $5
7" Pitman arm (straight, not drop) OE - $50
Sold: Used TBP Poly Fender flares $40
VIAIR 91050 Air Tank, NIB (used for mock up only - never filled), 5 gallon $50
Fuel Pressure Regulator, low pressure for Carb, non-return (dead head). Single inlet dual outle p/n 15952 $30
Original body side trim (no spare tire) $200
Bunch (?) of a BCB vintage a/c kit. Used and removed, let me know if you are looking for parts - N0T COMPLETE
York 209 Air Compressor for OBA - $125
Set of 15" aluminum rollers with ok BFG's $150
and more?
Hozr
Hozr
Rogue Valley, OR
Pics of kiser riser
Attached pics. The bottom hole where it goes over the stock trac bar stud got a little wallowed removing the weld but once you weld it on it'll work fine.
bronconut1
I sent you a private message about a problem with the speedometer cluster.
Status
