Stuttering and backfiring
Mmanders
I have a 68 with a 289, it has a Holley 2 barrel carb on it. It idles great but it is sputtering while accelerating and while cruising, sometimes it backfires or pops. I recently replaced the cap, rotor and spark plugs, and it is still happening. I bought a carburetor rebuild kit but I haven’t done that yet. Is there anything else I should look at? I don’t want to damage anything or get stuck out and about.
Does it still have points type ignition? If so you need to check that part too. Not just the cap and rotor, since the points and condenser are more likely to be culprits in most cases.
You'll need to check ignition timing and how it functions too, using a timing light and if you can, a tachometer. But the timing light is critical. You're looking for smooth advance workings and making sure it is advancing and not jumping all over the place.
Of course, it could be running lean too, so by all means check for vacuum leaks using any or the common test procedures for doing so.
When you look down the carb with the air cleaner off (engine off too) do you see two nice even squirts of gas when you push the throttle lever?
Is there a working PCV valve in one of the valve covers? Check to make sure it's working properly and is the correct part number (If that's visible still).
Tell us more about the engine. Is it original with tons of miles? Recent rebuilt with more than say, about 10,000 miles on it? Or a recent rebuild with just a few miles on it?
M
Mmanders
Paul, thank you for the response. Yes, it is a points system, I will check that.
The odometer shows roughly 27000 but my assumption is that it’s at least 127000. I did not get a lot of information from the previous owner. I believe it is the original engine and it’s got leaks that I need to fix.
I will also check for vacuum leaks as well as look in the carb at the fuel spray as suggested.
I really appreciate the input!
Good. Let us know how it goes.
With older paint on the engine, I don't worry as much about chemicals hurting them so my go-to "vacuum leak tester" is good old carb-cleaner spray.
With the engine idling spritz it here, there and everywhere there is a seam. Intake manifold edges, carburetor at the base, and along it's sides, any vacuum lines (even a '68 should have a couple) and wherever. If you hear the idle go up or down, or even just change the slightest amount, you have a vacuum leak right there.
If it's large enough to cause the engine to stutter under acceleration, it'll change the idle pretty substantially.
My guess is on the ignition though, at this point. Too early to tell of course, but we still have fun throwing guesses out into the mix!
Good luck.
M
Mmanders
I checked for vacuum leaks, did not find any. The PCV valve is definitely old and will be changed soon. We were able to pin it down to the vacuum advance. I have a new one coming in the next few days.
I will update once I get the vacuum advance in and verify that it fixed it.
Thanks again for the help!
Glad you found that, but if it does not fix the problem then if there is a way to check the power valve, do that too. I forgot you said "Holley" and I should have added power-valve to the list of things to suspect.
I don't know of a way they can be checked, but there is probably a test someone can quote. I always just changed them out when I started having issues. That would fix it for awhile, but never for very long. Then the backfiring and spitting would start again, and that would guarantee continued deterioration of a power valve. Yes, even the "blowout-proof" versions.
Never found that name to be accurate!
Good luck. Be nice if it's as simple as the vacuum advance.
M
Mmanders
I also have a rebuild kit for the carb, that is on the list to do as well.
Thanks again for all the help, I will update once I have a chance to work on it.
M
Mmanders
Finally got the vacuum advance installed. Fixed the issue and ran great tonight!
