supporting body after frame is removed ?
broncoinwisconsin
Reeseville, Wisconsi
i want to take my tub off the frame to sand blast and paint the frame and tub separate. so how do you support the tub ?, it is very flexable in the rocker area so i made a support from the top door hinge to the striker post but it still is flexing when i pick up on the back of the tub. i'm afraid to take it off the frame because i don't want to bend it all to crap. also the front inner fenders and radiator suppt. seam like they will flop around after there off the frame. just wondering what some of you guys have done , thanks.
broncobsession
sounds like you need to do some body work...the body should flex a little but not buckle in the middle at the rockers. Leaving the doors and tailgate in should help limit flex, but if you are lifting manually (you and your friends), it will be alot heavier. With everything disconnected, the front end should be pretty light, but make sure you take off the fenders, grill, and hood. No sense stressing the front end unnecessarily ;)
SteveL
Huge chevy guy
Hawthorne ca
get a tape of "trucks" on tnn. They did this not too long agoon their 66 bronco project. They sell em for $15 if you can't find someone with it.
alex69eb
dearborn, michigan
just be careful if wisconsin trucks are half as bad as michigan trucks on rust you may split behind the seats or the front may split off from the firewall. did it on a buddies of mine they set it down on the ground and the back half split behind the seats. not a good deal.
68bullit
i made a real big X that i bolted to the rear tailgate striker bolts and also bolted to the front upper dash bolts.<br><br>by doing this i could leave the doors on until it was ready to move then took them off prior to lifting.<br><br>i alsi ran to bars straicght down to the front outer seat bolts to help eliminate flexing while movving.<br><br>i used like 1 or 1 1/2 square tubing and made it hingable so it could store fairly flat
