Suspension Question
cjb
Ann Arbor
Would it be possible to run 2010-2014 SVT Raptor Fox shocks on an Early bronco with a 4 inch lift if I do the Duff coil-over conversion? Thanks
Interesting question. Do you have any specs on the mounting method and the lengths of the Raptor shocks?
I think someone asked this question a year or three ago, but don't remember what the answer, if any, was.
Interested to hear what anyone knows about that.
Digger556
The front coilovers? No.
Typical IFS struts are not well suited to solid axle applications.
1. The upper mount is typically a 3-bolt circle. You would need to machine an adapter.
2. The spring rate is too stiff. The IFS has approx. a 2:1 motion ratio between the wheel and shock. Solid axle trucks have a 1:1 motion ratio. The spring is easily twice as stiff as you need.
3. The shock valving has the same motion ratio issue as the springs.
4. Travel. Again, the motion ratio. The shock will have far less travel than a comparable solid axle coilover.
JefeAZ
Tucson
Found this on the rears:
