Suspension Woes
BWH
Idaho
I am new to the forum and seek some advice. I own a '72 Bronco Halfcab. It is mostly stock and I use it and intend to continue using it for hunting and fishing purposes. The stock suspension is very harsh. The image of a bucking bronco on the fender is well deserved. I do not intend to do any wheeling that requires a lot of articulation or clearance. All of the aftermarket suspension information I can find that advertises a plush riding suspension involves installing various amounts of lift. I don't care to lift my rig, I just would like to improve (greatly) on the ride. If you have experience with this particular dilema or can refer me to someone that can, I would greatly appreciate it!
I am willing to spend money, so the cost of a lift kit is not the issue.
ballistic64
Piedmont , SD
urethane bushings and new shocks is where i'd start.Replace the bushings in the front end and rear springs.If your rear springs are sagging OEM type springs are relatively cheap.
SteveL
Huge chevy guy
Hawthorne ca
urethane bushings can ride harder than the stock rubber ones. the front end rides kinda stiff unless you do something about the radius arms. Either longer arms or the WAH from BC. Most all of the aftermarket leafs will ride better than the stock ones as long as you go to an eb vendorr instead of 4 wheel parts for rancho or superlift. I run bc 3 1/2" springs on mine.
Since you're not reallly insterested in lifting, there are a few options still. Even though lifting, up to about the 3.5" level, is nowdays considered fairly mild and street-freindly. I've run from stock height to 3.5" lift and kept the same 32x11.50 tires and it looked and performed wonderfully.
BUT, if you'd rather not, then I would replace the front coils with some Moog CargoCoils. They are a modern variable-rate coil spring that is very soft initially but won't bottom out any easier because it stiffens up a fair amount as it compresses. You can buy the stock Bronco replacements, or do like I did and use the same vintage full-size six cylinder truck versions. I forget the numbers. The truck version is still softer riding than stock, but will lift you approx 1.5" over stock.
If you do lift slightly, then you can add a 1 to 1.5" block under your springs, OR, as I did originally, use an add-a-leaf in the back. I know that goes against the better riding premise, but if you've go the original rear springs, I bet they're pretty "set" and have sagged to the point that they are almost, or are resting on the much thicker bottom overload leaf. And the tips of each leaf eventually dig into their neighbors and make for a much harsher street ride. I did an add-a-leaf and it actually rode BETTER than it had before.
If you do remain at stock height or even with a slight lift, another option is to check with the Bronco vendors and see if they have any stock or low lift replacements that ride better than stock. If not, then you can have some custom made for not much more than the cost of a pair of lift springs. Another member here did just that recently at National Spring and I think he's pleased with the results. I don't think he's had much time to evaluate them yet but maybe he'll chime in here too. Eh Lou? You happy with the setup?
Good luck whichever way you go, but like the others said, it never hurts to replace the bushings and other wear components as the old ones can "take a set" just like springs can. Or if they fail completely, allow other items to bind up and ride harshly.
broncnaz
I also have a lift 2 1/2" the ride is very good compared to stock check out Bronco parts website they offer some stock replacements that will ride good you may also what to contact chuck at BC bronco's his website doesn't have stock rear springs listed but he probably has them. I use his rear springs with 2 1/2" lift built in they are not on his site either. you may want to get new quality shocks as was suggested I would stay away from the bottom of the line types( bottom line ranchos, no name types, superlift, hecklethorn, ect). I switched shocks that were only a couple of years old and it made a world of differance. but 34 year old springs dont help much either.
http://broncoparts.com/
http://www.bcbroncos.com/
Case
i have a old catalog from wildhorses, about 2 yrs old, and they list a stock height suspension kit with all the bushings, springs, shocks, etc. for about 500. i couldnt find it on their web site, but try giving them a call. i see JBG also sells stock coil and leaf springs.;D
B
BWH
Idaho
Thanks for the input. I have already purchased the graphite impregnated poly bushing kit from WH and will see what effect that has. Then I will go from there. I tend to agree with the idea that the 34 year old components are set and may just need to be replaced with new or less tired ones. I also looked at my shocks and found that 3 of the 6 shocks (duals in the front, don't know if that was stock or not) were loose in there mounts and I suspect inoperable. Lots of work to do! Thanks again. BWH
4x4Alaska
Wasilla, Alaska
you might also want to think about going with a single shock set-up in the front...might make things a little softer...double shocks is kind of overkill unless your doing some "baja hunting".....
Definitely what he said! Just eighty-six a couple of the old doubles. So, WHEN you buy new shocks, just start with 2 at each end and see how that works for you. Or if you for some reason feel you still need duals, make sure you purchase shocks specifically intended for use as duals. They'll be softer valved. But I'd just use one per wheel and be done with it for your stated useage.
