456 or above for gear ratio. You will have toget new carriers for both I believe. It will be a good time to go ahead and upgrade your rear axles to 31 or 35 spline. I did both in my garage as a first time experiment. I didnt have the fancy machinists tools for measurment, but I did use a die grinder to shave away the inner suface of the used bearings so I could instal/adjust shims without having to presson/press off the new bearing. 9 inch was easy, front 44 I lost a lot of skin on my knuckles a a couple of finger nails over the 3 times I have changed ratios. Definitly remove the tie rods on the driver side.....
I had 350's and 35" tires with an auto, went 456 gears until I installed the NP435. Tried 350's again(I was running the interstate every day) and finally settled with 411 gearing.
