I have a 70 Bronco that is fairly stock. I very rarely take it anywhere off road. I often take it on the highway. It has the stock 4.11 gears. With this, I max out at about 60MPH on the interstate. Gas mileage suffers as the engine revs so high. My goal is to get to about 70 MPH at a much lower RPM, and still maintain city driveability. I'm not worried about off-road gearing - using the low gear in the transfer case would provide more than enough for my needs.
I've been planning on changing the transmission to a NV3550, but cost and amount of work has kept that from happening. I just got the brilliant idea of simply putting in different gears. I found these: http://www.precisiongear.com/dana30.htm and http://www.precisiongear.com/ford9.htm. Looks like I could put a 3.07 in front and 3.08 in back.
Any reason not to do this?
Would those ring and pinion sets work in my Bronco?
What other parts or special tools are needed?
How easy would it be to do this for someone who has never touched a differential?
Any guesses on cost for a shop to do this? And advice on choosing a shop?
Has anyone seen even lower gears?
Thanks!
Thanks!
