@jamesroney is right, but….
It depends on your circumstance whether cut and turn is the right answer. If you plan on much 4 wheeling, then front piñon matters. If you are only driving in town, then it does not matter. Even with 15° of piñon, a 1310 can work under slow steady turning. Very much torque or prolonged use and the joint will fail. For me, mine is a show queen with zero off roading in its future. However, even with that fact, if I do another 4x4 I will cut and turn regardless of use just to get the right caster without having use aftermarket “fixes.”
However, to answer your original question: yes, they are excellent arms, very strong, well made, and provide easy caster adjustments. I have them and my driving went from scary, two hands on wheel to smooth, one hand on wheel and able to turn a corner while changing the radio station. Night and day with better caster.
