There are only slight differences. T-shift has a little better low ratio at 2.46, and an extra interlock pill between the shift rails. That extra pill makes more work for you if you want to twinstick and control the front and back independant of each other. J-shift is 2.34 low. Other than that the ends of the shift rails are different. You can swap one for the other if you swap shifters.
