Terkish
- Feb 22, 2008
- 414
So I removed my t-case and re-sealed it with all new gaskets and seals.
While it was out since it is a Tshift I decided to remove the pills and go twin stick.
I found the PO had apparently already removed the puills at some point. So I put everything back together and installed back in the bronco and now the front shift rod is stuck in neutral. The rear seams to work fine.
Did I do something that caused this to jam up?
When I get home from work I will post a picture of the insides of the tcase to verify the pills have been taken out.
thanks for any help.
