T stat for 351w
hankjr
Any specific temp thermostat to use on a 351w with exploder EFI? I've read about the 1/8" hole at 12 o clock. Interestingly enough, I came across the one that came out of the donor and it had a little ball check at the 12 o'clock spot.
Thx
Hank
sykanr0ng
195 degree for the Ford EFI
I would get a RobertShaw, very high quality, very reliable and consistent.
I know WH carries them, Summit Racing also.
tasker
all knowing of nothing
NH
use the factory Ford 192 degree....had all kinds of problems using the 180. runs steady all the time now. I know a guy that could get you one too!
Broncomt
The 1/8" hole is for ease of bleeding. You can buy thermostats with the hole already in them. Has nothing to do with cooling.
Most thermostats will have a weep hole. Not an actual hole, just a nip or kink to let the air bleed. 1/8" is massive, no need for that much hole. Air bleeds through small holes pretty fast.
hankjr
hankjr
Thx for all the feedback. I found a new 195 in my box of parts. Will simply start there
Hank
