Tail Gate Alignment
rmcbama
Birmingham
I started a frame off restoration, it got delayed, we moved, etc. Anyway I had all the body parts done at a body shop and am just putting everything back together. My issue is getting the tailgate installed. It's straight but found that the drivers side pillar is pushed in about a 1/4 inch and with a new tailgate hing, there's not enough clearance to install the gate. The bend begins at the rear drivers side body mount and angles towards the front. The drivers side appears to fit up nicely but the gate hits the body at the area around the body mount.
I'll need to figure out a way to keep the body and frame in place while I place enough force on the pillar to pull it out slightly. I'd like to hear any ideas you may have. I'm considering taking it to a body shop to get it on a frame straightener to see if that would work.
Any thoughts would be appreciated.
kip60
Might try to put a 2x4 on the pillar and wedge another from the bottom of the other side. Cut the longer one a tad bit longer than the opening and tap it down from the top. That would keep your paint damage to a minimum, if any. You could also cut one short of the opening and use it as a fulcrum with a longer piece up the pillar. You could then pull the longer piece out against the pillar to bend it out. My .02. Like to always start with something readily available before getting into the big stuff like frame pullers.
rmcbama
rmcbama
Birmingham
It's actually pushed in towards the front of the vehicle. I'll need to pull the pillar area straight back.
rmcbama
rmcbama
Birmingham
I tried some pulling from the back but not from the inside. I'll try that and see if I can get it moving. Thanks
kip60
Towards the front? Yikes! Maybe get something down the hole that the top reinforcement post goes in and try to wedge it out from there. Wrap a pipe with cloth to keep it from messing up the paint. 1/4" is going to be hard to do without popping something. I always try to mock everything up before I paint anything for that very reason. (And that doesn't always work either!)
You may have to shim up the body mount behind the drivers seat. Check the square of the drivers door opening from the ledge of the drivers side rocker panel to the opening of the back face of the door. Check the level of the top of the bed side and compare the drivers side to the passengers side.
jmangi62
A similar thing just happened to me,I'm at the end of my resto and the very last thing was to install the tailgate,well I go to install it and the opening was too tight,had to cut the lower support in several places to pry it open enuff to have enuff clearance,well now I have a shitload of bodywork and repair to do,this sets me back as I was ready to drive the rig after 3.5 yrs of work,oh well isn't that the fun of building a car from scratch?LOL. :mad::eek::(
