I loosened up and removed one side of the bottom tailgate hinge (2 bolts) and then pull the tailgate up (closing it action) while causing the tailgate latched to fold in reverse (up) and then it will get to a point 3/4 up that you can pop them off the body and then remove the tailgate. This is what I did.
As far as getting stuff out haha good luck!!! I failed in that attempt even with everything removed...rattle rattle rattle...
The bottom of the tail gate has very small drain holes. The stuff ratteling around in your tail gate is likely bigger than the drain holes. I took mine off and drilled a large hole in the center of one of the pivot insets on the tailgate and dug all of the rust out. You are then going to have to weld the hold shut. Even if you don't weld it up, it shoudl be ok.
8 bolts is all it takes, where the pivots bolt to the body and arms bolt to the body. Just make sure you disconnect the license plate light wire if you are going to drop the whole tailgate off, I almost snapped mine!
