MnkyBiz
There have been lots of threads on this.
the room behind the tail gate handle is NIL.
Just a thought so see if someone else wants to run with it is....
Install a Cam Lock above the tailgate handle. The arm of the lock will rotate DOWN into a slot cut into the handle, effectively making it impossible to pull the handle outwards & open the gate...
.....sound like a reasonable idea?
If not, then someone needs to make a handle assembly from aluminum & have it as a bold on replacement of the old handle.
You do it....I'll buy it!!!!!!
