- Nov 3, 2003
- 51,617
Bedliner on the inside doesn’t change anything. You access the rods from the outside through the latch release handle mechanism.
I don’t think shrink tubing would be worth it. Most of the rods if I remember correctly, have at least one 90° bend in them. I think they have those at both ends, but it’s been a couple of years now, so I don’t remember the exact orientation.
Someone will have a picture though, so I’m sure it will prove out that shrink tubing would be awkward at best, and as was already said, too lightweight to make a big difference as you might want.
Unless you’re just talking about padding the very ends were they insert through the mechanisms?
In that case, they would absolutely make at least a small difference. It would change the pitch of the rattle, but I doubt it would get rid of it 100%.
I take that back. That would probably work very well if you got the sizing just right.
What mof us have done is simply weight and dampen the rods themselves.
Cushioning the ends where metal touches metal would be a great idea as well though.
