I am working on a tailgate for my 72 and found more rust (big surprise!) after I cut off the bottom to use the replace panel - the extra rust i found is on the inside bottom where there is a embossed line which I assume is for the weatherstripping and/or strength on the flat surface. I am inclined to just cut that whole section out and replace with flat stock. Anything wrong with doing it that way? i couldn't fabricate that relief in the metal again.. i could weld in a 1/3 of round stock of some sort and maybe get close but would like to avoid warping stuff if i can.
Also what is everyone using to repair the round ends where the hinge sits? Hole saw it out and hole saw a piece of flat stock and weld it in?
