TBP floor shifter - Won't go in Reverse
bmflinchum
Roanoke
Ok so I got tired of the column shifter and got the Tom's kit to convert to 3 on floor. Following all instructions (they kinda suck) and the 1-R shift lever (mounted on trans) hits the transmission tunnel brace. Everything is installed as the drawings show. Any suggestions?
73azbronco
maybe a picture? Which means you have to be a contributor sorry, but I can't imagine what the issue is without a photo
serial car restorer
Western Oregon
Tom's webpage on this kit has the following note:
"Fits 66-77 Ford Broncos with 289, 302 or 351w V8 Engines and Factory Manual 3-speed Transmission. NOTE: When installing this shift kit, the underside of body may require cutting a small notch for clearance."
Might be relevant?
bmflinchum
bmflinchum
Roanoke
EPB72
Pleasant Hill, CA
extended inline die grinder might help,, harbour freight sells pretty cheap ones with 3 in cutting wheel, an belt file may help as well to clean up cuts
JeepGuy
I think with the right grinder and a cutting wheel you could get up in there. Remove the linkage, take the shield off the grinder, and put on a new cutting wheel. Just gotta work the angles. Kind of had to do the same thing for the winters shifter cable and it took a bit of head scratching to figure it out.
I'm guessing by the look of it you do not have a body lift? Worse case scenario you could loosen all the body bolts and jack up that side of the body to create room.
JeepGuy
Another thought here.... This is a great opportunity to put a 1" body lift on there and it would probably take care of your clearance issue (just based on the picture) without having to cut anything. 1" isn't too crazy and you might be surprised how much your old body mounts (assuming you haven't replace them) could be sagging.
bmflinchum
bmflinchum
Roanoke
This is the route I have chosen. 1" body lift and new bushings ordered.
So does that mean you ordered replacement body bushings AND separate 1 inch spacers? Or did you buy a 1 inch body lift that includes 1 inch taller body bushings?
bmflinchum
bmflinchum
Roanoke
Lift and bushings. TBP has the lift and recommends the bushings also.
Got it. Thanks.
It’s OK, either way, of course. But if the lift is done with spacers, like traditional lifts are, the new bushings are certainly called for. Especially in a “while you’re in there” kind of way. 😁
It can be either an easy job, or a really big hassle job. Hopefully yours is the former!
bmflinchum
bmflinchum
Roanoke
If my luck is the same as before it will go from a 2 hour job to 3 days real quickly
JeepGuy
Lol.. Yup. If you are waiting on parts I'd suggest letting those body mounts bolts soak up a bit of oil to help with the process.
bmflinchum
bmflinchum
Roanoke
I wish….. I’m out of town for work. I travel for work so parts will be there when I get home.
bmflinchum
bmflinchum
Roanoke
Closing the loop here....
Body bushings replaced and new 1" body lift installed. Took me all day and had to adjust the clutch rod. Had to cut most of the old ones out burned through a bunch of blades.
Now the shift works perfectly fine. Also gave me a bit more clearance on rear for the tires.
