Ok, thanks for the info. One other issue now....
I've just test fit the starter to the bell housing and there is no way it's engaging with the flexplate. Looks like the gear on the starter has has about 5/8" mounting depth. I measured the depth of the block plate mounting surface to the flexplate and its easily over 5/8". To grab the gears it looks like it would need at least 1".
I have a Bronco C4 with 164 tooth flexplate and the Auto mini starter from Tom's. I'm fairly sure the flexplate etc is installed correctly as Viperwolf1 bolted it up.
Any ideas?
https://www.coasthigh.com/ProductDetails.asp?ProductCode=SCA-FP-302E-SFI
Item Code SCA-FP-302E-SFI
Vendor Name SCAT
Product Type Flexplate
Application 11.5 Converter Bolt Circle
Engine Family FORD-LINCOLN-MERCURY - Small Block 302 Based V8, Small Block 351 Windsor Based V8
Balance Style 28.2 oz/in External
Ring Gear Tooth Quantity 164
Safety Rating SFI-approved
