Teflon Tape and Evilness!!!!
broncoitis
Ok, everyone is probably gonna laugh at me for using this stuff but how did I know? %) Building and modifying this truck has been an adventure no doubt that sometimes I really have to question myself for doing it and saying a restomod Bronco would be awesome! Blah, Blah, Blah!
Ok, sorry! Went off tangent there for a moment. Back to the Teflon Tape issue and EFI. I hate leaks and used this as a precation on the pipe threads on my water temp sensor! Well just yesterday I came to find out that you should never use teflon tape in the assembly of an engine. It has something to do with the electric grounding ability of the sensor being blocked and messes with what information that your computer is getting from the sensor and as a result could drive you NUTS wondering why your engine just won't seem to run right.
Now I have not confirmed this yet with my engine because I have the throttle cable disconnected currently to improve its function but I am gonna remove the Teflon Tape that I have wrapped around my threads and reinstall the Water Temp sensor that the computer is reading and see where that gets me with my High Idle! I have been told that this is like a little miracle waiting to happen! Maybe some of the GURU's on here can better explain the EVILNESS of TEFLON TAPE and engines sensors!!!! ;D
Just a heads up and I will chime back in with what happens to the idle. Hopefully with good news. ;D
broncoitis
broncoitis
Ok, removed the tape but there is also paint in the pipe threads which are probably effecting the grounding of the temp sensor! On top of that problem, the tube setup that I have the temp sensor in from the mustang also has another area where the twin metal tubes that run under the throttle body are threaded into the top of the manifold. Along with the teflon paste that I used there is probably powdercoat on the pipe threads and possibly paint as well. Might have to remove and clean that as well if it is possibly affecting the grounding of that sensor! :mad:
Ugh! This is gonna turn into a PITA!!!!
Gonna get a brass dremel bit to clean the threads!
Can anyone confirm if these sensors are or are not grounded through the threads on the Mass Air setup???
AZ73
There are liquid and paste thread sealants that are made for use on sensors/senders. One of the products comes in a stick applicator it is Locktite PST Stick, Item Number 37615. Or use a liquid PTFE (Teflon) paste. Teflon pastes do not impede electrical contact between parts in a threaded joint. They simply fill voids that allow the contained meduim to leak out of the joint. The threads still mash together and if properly tightened will have just as much contact between each other as if no paste were used at all. Just not the tape.
broncoitis
broncoitis
Thanks AZ for the confirmation! I honestly dont remember if I used paste or tape! However I did use some type of teflon and as a result of the lack of memory I have to make sure it is all gone for a good ground! I can also see teflon on the Air Charge/Temp sensor in the upper manifold so that should be cleaned up as well I suspect. Can't hurt I guess. What about Anti Seize? I guess I will go and get the loctite paste but wish that I knew about this before hand. Oh well, I guess all part of the learning curve.
On another note, messing with my gas pedal/throttle setup and there are these angled wedges that angle the throttle cable more directly with the gas pedal. Well, I was lucky enough to DROP the one in the engine compartment and the )#&$ing thing didn't hit the floor but got hung up somewhere on the engine. The Fun just keeps coming today! WOOOO HOOOOOO!!!!! :mad::mad::mad::mad::mad::mad::mad:
bknbronco
North Metro, MN
I don't see how tape would not make a ground connection. If you have ever taken things apart that were taped the edges of the threads still end up cutting through the tape and would be infact making a metel to metal connection. I have a tiny tube of white Teflon thread sealer that I keep next to the antiseize and the blue locktite. The problem with the tape is that's its a bitch to get cleaned out of the threads. Also most people don't realize that you need at least 5-6 wraps of tape to really seal it up good. Im sure you just did the normal 2-3 wraps.
I wuldnt worry to much about it if you did use tape. But in the future get yourself some thread sealer liquid.
Also most every sending unit I have bought (temp, oil, etc) came with sealer already on the threads. And I love when brake pistons come with sealer on the bleeder because without it I notice that I get false air bubbles from the threads when I think its in the actual lines.
El Kabong
Driving stuff Henry built
You might try connecting a jumper wire from ground to the body of a suspected sensor to test the theory without having to take anything apart.
ransil
I would just check it with a meter and if its zero ohms call it good.
El Kabong
That's ^ true. Just measuring from the body of the sensor to ground should tell.
broncoitis
broncoitis
Ok, so if the sensors are grounded through the block which I know is grounded to my frame, I guess all the bolts that hold the Manifolds to the block and what have you connect everything. What if you powdercoat the manifolds and the gaskets are preventing the intake from making contact with the block and the powder coat is preventing the bolt from making good contact with the manifold and grounding to the block couldn't that possibly cause a situation that you probably have a questionably grounded engine in certain areas? Two of these important sensors are tied into the intake which I suspect is questionably grounded. Water Temp Sensor and the Air Temp Sensor (which is connected to the front driver side of intake). You can just see it behind the #5 injector in the 3rd pic. Maybe this is all a waste of time and for nothing! %)
broncoitis
broncoitis
Im not a mechanic and still learning so what do you mean? Meter on ohm setting and put the positive on the body of the sensor and the negative on a good ground with it running I assume? I should read ZERO ohms! ?:?
Thanks for the help. I will get this engine to run like it should.
jasonb
Howard City, MI
The ECT (engine coolant temperature) sensor is a 2 wire sensor and is grounded through the harness, not through the base of the sensor. The temp sender for the gauge is a 1 wire sender and is grounded through the intake or coolant tube it is screwed into. Either way, thread tape or sealer should not affect the path to ground. The sensors when new from the factory have thread sealer already applied to the threads, and this is probably what you seen under your thread tape. At the dealership I use liquid Teflon sealer on waterpump bolts, sensors, or anything that screws into liquid.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Ditto what jasonb said, I think. I mean, the sensors (ECT and ACT) that screw into the intake have plastic housings and two wires anyway. So I used pipe thread paste. I have always used it on the temperature sensor, too and to my knowledge it has never been a problem. (Notice that little caveat there.)
broncoitis
broncoitis
Ok! That is a simple enough answer for me. That would make sense with the two wires coming off of the sensor. Thank You!
patterdale
The tape only fills in the voids to seal the threads. You should have enough metal to metal contact to ground anything if it needs it.
