Teflon tape on fuel pump?
RollTideMach
Birmingham, AL
Can i use teflon tape on the threads of the fuel pump where the SS pump to carb line threads in, or will the gas eat it/ turn it into gel and clog the new pump?
Thanks, Keith
RTV is very bad in fuel systems. Swells and goes gelly like.
You should not need any type of thread sealer at all on any fitting unless it is tapered pipe thread. If that is the case a very light teflon paste at least a thread back from the end.
The teflon is not suppose to be a sealer. It is suppose to be a lube so the tapered pipe thread will wedge in tight enough to make the seal.
rsharpnm
Las Cruces
I used to think it was smart to put teflon tape on the fuel filter-to-carb threads. Right up until I was picking little strings of it out of the needle and seat.
Don't think it is a good idea, personally.
