- Aug 23, 2007
- 24,448
Anyone know of any good pricing on some TL Bronco gears?
why don't you just spend the extra $ and get the Atlas II.
Terra Low gears, plus HD output shaft, why don't you just spend the extra $ and get the Atlas II. I know it's another 1K, but that would be the last transfercase upgrade you'd ever need. I find it difficult to spend $1200+ on my old Dana 20. I suspect some have already bought the HD output shaft. I've only upgraded to twin sticks, and carry a free spare output shaft assembly. I think it will be easier to decide what to do when mine breaks.![]()
I'm always curious as to why people choose to do what they do, especially on bigger ticket items like this. I've done nothing, but want to do something. So I like to hear why others have done what they did.
I'm in the same situation. Twinstick with T geared J shift. Spare output housing on board.
The D20 is a pretty tough tcase. Something has to be seriously wrong to destroy it. I just rebuilt one (built would be a better term) that had broken teralows, HD output and a split case. The HD output housing was broken around one of the bolt holes. The case split because of the broken low range teeth. The question was what caused the teeth to break. The rear T shift rail was previously modified to prevent the front/rear from getting crossed up. However the grinding was a little too short. This caused the low range gears to become misaligned in front and rear low. This lessened the contact area between the cluster and sliding gears. That is what caused the teeth to start snapping off. Sometimes its the little things that cause the big failures.
I fixed the shift rail and rear housing and stuffed the new gears in a good used case. I don't expect it to fail again.
I'd call Tera and see if you can just get the gear(s) you need to replace the broken ones. Might be cheaper than getting a whole set.
