Tom Hartz
- May 18, 2010
- 214
I am about to start drinking. I had to change the thermostat housing from the stock design to one that is 90 degrees to clear the added Vintage Air compressor.
Here is the stock one I removed.
This is the one I am running now.
I have tried to seal this thing at least 5 times. There is a small seep between the manifold and the thermostat housing.
The manifold is a Edelbrock Performer on a 1969 Ford 302. The thermostat housings fit a Mustang or Explorers with a 5.0.
These are the things I have done.
1. Fel Pro gasket.
2. Stant gasket. (This one fit the best.)
3. Checked the housing on a piece of granite to be sure it is streight.
4. Permatex Ultra Black silicone and letting it dry over night. (A little, not thick.)
5. Permatex water pump / thermostat housing silicone.
6. Put a straight edge on the manifold to check it.
7. Tried a different thermostat that was a little thinner and of better quality to make sure it was not holding the housing out.
8. Clean, Clean, Clean. I have made sure all surfaces are clean. I have even wiped them down with lacquer thinner.
9. I put a small dab of silicone on the thermostat to make sure it did not drop between the gasket and housing.
10. Checked the bolts to make sure they did not bottom out first when tightning.
Before I go and spend $90.00 plus for a billet O-Ringed housing,
does anybody have any ideas that I can try?
If it will work I have no problem spending the money.
I am sick of this.
Is the problem with the earlier manifold and a later housing? They look like they should work together.
Thank you.
Tom
1. Fel Pro gasket.
I am sick of this.
Thank you.
Tom
