The Obscure Machine Build.
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
Since I'm keeping the Bronco, I will continue to work on it. At some point, probably after moving to a place with four seasons and that has a garage, it will be torn down for a frame-off.
Totally misrepresented by seller:
Here's what I purchased:
"COMPLETE RESTORATION!"
What Was Advertised............................................................................................Reality
1973 Bronco Sport........................................................................................................ACTUALLY! IT's A 1974! (Thanks unscrupulous seller!)
4x4..............................................................................................................................Transfer case didn't work in 4 Hi or 4 Lo
Power Steering..............................................................................................................Pump was groaning moaning and DOA. Had to be replaced.
Good Brakes! .....................................................................................................Hard line to pass front was CRUSHED! Left front brake didn't work at all
...................................................................................................................................Rear Brakes were shot and had to be totally redone
...................................................................................................................................(Brake warning light was on. DB said "it's just the light. Only needs to be reset) Moron!
New Exhaust!...............................................................................................................Headers rusted through. intermediate pipes rusted through. Mufflers had GIANT holes in them. Pipes from ...................................................................................................................................only mufflers back were "new"
302 2v with only has 35,000 original miles....................................................................... engine had been bored .030 over
2" Suspension Lift.........................................................................................................No lift at all. Just the fenders had been cut really high up.
New seats ...................................................................................................................WERE. NOT. BOLTED. IN! No seat belts!
---------------------------------------------------------------------------------------------no seat belts
---------------------------------------------------------------------------------------------Rear Seat was old, dirty, moldy and torn. Frame was rusted.
NEW 33" BFG M/Ts.......................................................................................................Dry rotted and cracked on the sidewalls, chunks missing.
Rollbar.........................................................................................................................NO BOLTS! NO WELDS! It was just "screwed" in with 1/2" sheet metal screws! REAL SAFE!
New Heater Core...........................................................................................................Awesome. BUT! Heater fan didn't work. Temp control wasn't even hooked up.
NO RUST..................................................................................................................... Both floor pans rusted (had to be replaced). Cowl rusted and covered with diamond plate.
---------------------------------------------------------------------------------------------Wheel wells rusted. Covered with bondo and bed liner
---------------------------------------------------------------------------------------------Hard Top completely rusted and unsalvageable
---------------------------------------------------------------------------------------------Frame where steering box attaches, RUSTED THROUGH! everytime I turned right, the frame bent.
----------------------------------------------------------------------------------------------It finally broke. Frame had to be cut and a new piece welded in. Added a steering box reinforcement kit.
All new lights.................................................................................................................Gauge lights didn't work. turn signals didn't work. reverse lights didn't work. Headlights only worked on high.
All Gauges Work............................................................................................................Gas gauge and Alt. gauges didn't work at all
Dual Gas tanks..............................................................................................................Aux tank had a crack on the inboard side about 1" up from the bottom. It ran the entire length of the tank.
---------------------------------------------------------------------------------------------After putting about 2 gallons of gas in it, gas started POURING out of the underside of the tank. REAL SAFE!
All New Weatherstripping................................................................................................
attachment.php
New Stereo CD Player.....................................................................................................Didn't work. Wasn't hooked up. Wouldn't work if it did.
Plus
*Door locks wouldn't open with keys
*Bedliner sprayed everywhere underneath, including on the brakes (had to clean it off just to bleed the brakes
* choke cable was actually run through the firewall, then turned went back into the firewall and connected to the heater.
* Battery had no "hold down" and was flopping around.
* "New seats" were stuck and would not slide
* Windshield wipers worked sporadically.
* Starter was shot. It took 3 or 4 attempts before it would engage
* Fuel pump was leaking and had to be replaced
etc., etc., etc.,
All of this on a bronco that was a "COMPLETE RESTORATION"
What I've Done:
  • Clear Front Turn Indicators and black gaskets
  • Front Disc conversion w/ slotted rotors
  • Warn Premium Hubs
  • F-250 Camper Special M/C (1 1/16" bore)
  • New front hard brake lines
  • New Front braided brake lines to calipers
  • h-4 headlight conversion with relay harness
  • Rebuilt gauge pod with electroluminescent gauges and LED turn signal indicators and high beam indicator.
  • New Starter Solenoid
  • New Horn Relay
  • New Hoses and Belts
  • Tom's Saginaw Steering Pump and Brackets
  • Mounted seats with grade 8 bolts and washers
  • New Chrome rear tailight bezels
  • Hood Shocks from JBG
  • Removed Aux gas tank
  • New Hedman Elite Coated Headers
  • Dual 2 1/24 pipes
  • Dual Flowmaster Mufflers
  • New Water Pump
  • Edelbrock Performer Intake
  • Edelbrock 500cfm carb (elec. choke)
  • K&N Filter
  • Chrome Summit Air Cleaner
  • New Oil Pressure Sending Unit and extension
  • Duff Steering Stabilizer
  • New Tie Rod, Ends and Drag Link
  • New Trac Bar Bushings
  • BCB Steering Box reinforcement (cracked frame re-welded)
  • New 132dB low-tone horn
  • New Window Cranks
  • Tuffy Console
  • WH 3 point harness
  • Carter 4070 Electric Fuel Pump with new hard lines and braided lines with -AN Braided Stainless Brake lines
  • Rebuilding rear brakes
  • various anti-theft pieces
  • Liftgate shocks
  • Replace rusted drivers floor pan
  • Bikini Top
  • new body bushings and WH 1' BL
  • Replaced sheet metal screws holding in the roll bar with plates and grade 8 bolts
  • Installed BCB gas tank
  • Rewired entire engine compartment
  • Installed new glove compartment
  • Installed new body mounts
  • Installed WH 2" Body Lift
  • Installed Bikini Top
  • Installed Custom Radiator Overflow Tank (Chrome Fire Extinguisher Canister)
That's where I am.
JGbronc
Bronco Maniac
I like how your 1000th post is the start of a build thread. Congrats!
Keep us updated on progress, with plenty of pics! I'm excited to see how it turns out!
JGbronc
Bronco Maniac
he not even close to a post whore!
Thus why I said "bit" of a post whore. He hasn't reached the top level of post whoredom just yet, but is well on the way. Not saying it's a bad thing. ;D
JGbronc
Bronco Maniac
Sorry I hijacked the thread with my joking. ;D (Was completely joking, just so you know)
So how did the body lift and roll bar fix turn out?
ObscureMachine
ObscureMachine
World Headquarters
Turned out good. Genius PO used TINY screws to mount it. I yanked hard on the par and it pulled right out. :mad:
So, I drilled bigger holes. Used Grade 8 bolts and nuts with large washers. It's not as safe as it could be, but I feel much, much better about it.
ObscureMachine
ObscureMachine
World Headquarters
Got out all the body mounts today. Took some pics. I'm thinking about writing a tech article on how to / how not to get these out, especially for people with limited tools.
This is what I looked like after a day of wrenching:
sprdv1
REBEL
LOL, wear jeans dude.. ;)
I have to force myself not to wear shorts, it's all good...
Keep up the good work
ObscureMachine
ObscureMachine
World Headquarters
Starting on the BCB tank. Started with this (pic), cleaned all the crap and rust from the frame and sprayed it with rust reformer. I'll post a pic of that later.
Also, PO aka "Jerk Weed" (from Die Hard) used little screws to hold in the roll bars. Don't know if that's correct or not, but I didn't like it. So I pulled them and installed some Grade 8 bolts with large washers underneath. I can't weld and have no welding equip, so this seemed like the next best thing to do.
Do these screws make sense to you?
