The Obscure Machine Build.
ObscureMachine
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
Yes! This thread is lacking in pics, bad! ;D
Well, it's dark now, so here's a bronco relevant pic for you:
attachment.php
half cab
Guru Bronco
Jimmy,?:?I can't see it or it can't see me ...one er the other...I don't know...?:?
broncoitis
Jim,
Hope that the regulator works out for you and more pitures of whats goin on down ther in the BAYOU!!!! ;D
ObscureMachine
ObscureMachine
World Headquarters
Flying to Ohio tomorrow. So again the bronco is covered and I can't work on it for 9 days. Away from it 17 out of 23 days. Lots to do when i get back!
ObscureMachine
ObscureMachine
World Headquarters
Fuel kept running out of the carb down into the engine. Bronco ran really rough with lots of fumes. After putting a pressure gauge on it, I set the pressure to 4psi. Gas was still filling the carb and spilling into the engine.
So I pulled the carb (grrrrr) and decided to re-rebuild it. Probably overkill. It probably just needs cleaning or needles and seats replaced. But oh well. Might as well take it apart and be sure.
jim3326
Appleturkey
Check the float needle, it has a rubber tip that could be eroded and allowing fuel to keep flowing after the bowl is full.
Jim W.
Skiddy
I seen that, hope the rebuild fixes it
