Gravel Maker
Why the threaded holes? That would make it a much more expensive bracket...if you could make the zero degree frame brackets with threaded inner holes that would be perfect.
And never look backTime to take that step!
It is all in the setup. If I were building a DD that onlt rarely sees offroad I would do things differently. I would build a single triangulated (upper) 4 link, leaving the lower rear with no more that 10 degrees triangulation. My only issue with a 4 link on the road is rear steer from the likes of potholes at 60mph. With a double triangulated rear that can get scary, single avoids the issue entirely.Would your link system work for a vehicle that sees more daily driving than trail use? I saw a competitors 4-link system that said it was not suggested for a daily driver.
