The Tricky EcoBoost Early Bronco Build
Tricky Dick
Tricky Dick
So I've been thinking of ordering a 23 gallon tank for black friday, but ultimately I'm not happy with any of the options between pricing and fit for my stretch. So I'm building my own. Got it drawn up today and sending the file off for cutting/bending. 20.5 gallons. I designed it for a 15-19 F150 pump.
If these turn out like I'm hoping I'll probably start producing them.
hunter1
Maryville, Tn
I did my own too. Coulda saved you a little time drawing if I’d known. I made a couple of them,put one in my frame and traded around with a buddy for him one. Had no fuel in mine yet, but pressure tested with 5 psi air and spray bottle of soapy water and no leaks. Saved $$$$.
Tricky Dick
Tricky Dick
I did my own too. Coulda saved you a little time drawing if I’d known. I made a couple of them,put one in my frame and traded around with a buddy for him one. Had no fuel in mine yet, but pressure tested with 5 psi air and spray bottle of soapy water and no leaks. Saved $$$$. View attachment 935294 View attachment 935295
Nice. I did start off with somebody else's drawing, but I had to change quite a bit to accommodate the 6" axle stretch and the modern fuel pump.
.94 OR
With the design of that tank (pump plumbing) do you have an access through the floor to disconnect in case the tank needs dropped with the body in place?
Tricky Dick
Tricky Dick
A trap door wouldn't be a bad idea.
I have the pump offset to the driver side and all fittings should be accessible from behind the tire.
rcmbronc
Tomah WI
I built mine with the recess in the middle and it is almost impossible to disconnect the hoses. I disconnect at the filter and I put a joint on the return line to take apart. No room there to work very well. Just make sure before it is too late.
Tricky Dick
Tricky Dick
I don't have it 3D modeled, but imagine @hunter1's recess but rotated to the driver side.
Tricky Dick
Tricky Dick
I've been under the weather this week so decided to knock out something easy. The Intellitronix cluster reuses the original front bezel. I was debating on prettying it up but the Scott Drake bezel covers it all.
Tricky Dick
Tricky Dick
I put in a Barnes order for the 4 link stuff, except for the truss. I was locked in on the JL M220 truss, as far as I can tell it will fit the Ranger M220 perfectly, both pumpkins seem to have everything in the same place. It had come back in stock earlier this week but they sold out already.
I have a new problem from the stretch. 😬 The rear crossmember is right in the way of the eventual truss/link mounts, leaving me with 2" uptravel. I think I'm going to add another arched high clearance cross member a foot forward and then cut the old one out. Any holes in my plan?
Tricky Dick
Tricky Dick
Merry Christmas everyone. Updates will be paused for a while as I have taken a 6 month contract job out of state, unless I decide to bring it with for something to do away from home. I need to get settled in and see if that's viable before doing anything.
nvrstuk
PNW
Looking good... I'll tune back in come June! :)
