"The Turd" build Thread...
tasker
all knowing of nothing
NH
real good notes....ya never know...Looks far less intimidating laying there like that Steve..
FRANKO289
Bronco enthusiast
THANKS .... for the rims !!!!
FRANKO289
Bronco enthusiast
before and after pic !!! 30 min in my new sandblaster w. Glass Bead Blasting Media #9 !!!
WORK GREAT !!! ;) ;D
fatboy
Glad to be here.
New Hampshire
Maybe I should have kept them Franko! All kidding aside, those look great, and thanks for the feed back on the glass media. I have a bag I have wanted to try in my blaster and have another set of the same rims. :cool:
76MaBronco
76MaBronco
Massachusetts
Well, just as an update, I'm waiting for parts to finish up the mechanical aspect of it all...I've ordered and recieved my new exhaust manifolds (stock Explorer ones) and have the seats out. The rear is going to be recovered to match the Explorer seats I'm putting in (Oooooo, power seats). I'll be ordering the reverse rotation water pump today and a timing chain so I can freshen up the front while still using my newer stock-style aluminum radiator. Once I get the trans adapter, I'll finish up the mechanical part and concentrate on the electrical part (also known as the nightmare portion). I'll keep you guys updated and will post pics once I get going again.
76MaBronco
76MaBronco
Massachusetts
The trans adapter showed up on Wednesday!!! Hopefully I'll be installing the transfer case to the 4R70W this weekend, fabbing up my cross member and getting it all buttoned up mechanically...then comes the wiring nightmare...
pics to follow!!!
76MaBronco
76MaBronco
Massachusetts
I may not be...changing a cracked exhaust manifold on a '94 Jeep with 205k down at the shop (not my garage). The motor has never been touched and I just KNOW I'm going to snap each and every bolt...(SNNNNNNAP!!!!!) drill, sharpen the bit, drill, sharpen the bit, drill, sharpen the bit, tap...repeat 11 more times...:mad:
I'll let you know though. I'll definitely be working on it on Sunday.
jmhend
hey Steve, let me know to.. I owe you a few hours of labor, just remember not to throw away my step stool...
76MaBronco
76MaBronco
Massachusetts
You don't owe me anything Jay, You gave what you could, stayed a second day and I gave what I could...We're good in my book!!
And now...(drum roll please) The trans install!!!!
76MaBronco
76MaBronco
Massachusetts
Okay, so the trans is in. Kind of a pain without a trans jack, but not impossible with some help (thanks to my Jeep buddy and fellow BYOB volunteer, Jamie).
First of all, the AA instructions are better used as recyclable printer paper (remove the staple first) ;D But I have to say that the instructions were made for a ZF and not a 4R70W.
The adapter comes nicely machined and with all required hardware.
Some pointers:
- Press the bearing onto the shaft first. The press fit on the shaft is tighter than in the aluminum housing (at least in my case it was). Try to press the bearing on the race that its mating to (inner race for the shaft, outer race for the housing) this limits the side pressure that the balls exert on the race.
- Insert the snap rings, one for the bearing, and one for the reused gear on the new shaft (you have to reuse that one, so take care in removing it).
- Clean all the surfaces (I used acetone) and apply a liberal coating of blue RTV silicone to the o-ring groove and spread it around. Make sure that the roller bearings don't fall in when you tap the smaller housing into the transfer case.
- The gasket between the larger housing and the transfer case needed to be trimmed - the center hole was too small in my case. Make sure the transfer case spins as freely as it did with the old adapter.
- Install the larger housing over the smaller one. The small drill point on the larger housing indicates "TOP" (no mention of this in the instructions, I thought that was valuable info).
- Try not to mar the surfaces, as they are closely matched to the trans. One little dimple and you'll have trouble getting it on the trans.
- Trim the shaft on the trans down about 1/2" (I did it enough to almost eliminate the center pilot hole)
- Trim the webs on the trans as shown in my pics in order to use the included T-shift adapter (the J-shift won't work, another thing you don't find out until you open the less-than-informative-instructions)
- You'll also need to cut a round boss off the drivers side of the trans to let the transfer case rear output shift into low range.
- Bolt it all up and you're done!! I used the center hole in the series of three clocking positions and the transfer case came out clocked close to original.
Now for the crossmember. I saved both the original and the Explorer thinking I was going to be able to Frankenstein one up...no dice. I took the original Explorer one and added 3-1/2 inches to each end after squaring up the ends with a cutoff tool. Welded up some 1/8" stock to extend it, flipped the original cross member frame brackets on the frame and now it'll bolt right up with a couple new holes...
Here's the pics!!!!!
1. Smaller housing installed
2. Larger housing installed
3. Gap before shaft trimming
4. Shaft before trimming
5. Shaft after trimming
6. All bolted up
7. Shift rail interference
8. Cut, drilled and clearanced for their bracket
9. Another view of pic 8
10. Bracket installed
11. Another view of 10
76MaBronco
76MaBronco
Massachusetts
More pics...
1. Explorer cross member trimmed
2. Other side
3. Whole Enchalada
4. Additional metal welded on (but not finished)
76MaBronco
76MaBronco
Massachusetts
what shifter are you using? column or floor?
I have a floor now, I plan on keeping it, just relocating it. I'd like to go column, but that's more money than I want to spend right now...
are you planning to use the stock bronco manifolds?
I had to buy new stock manifolds as the originals were toast (and they were only $50-60 each). I plan on using the entire exhaust system including the cats and the new muffler Tasker had put on a little while ago. If it wasn't so new, I'd be putting a Flowmaster Super 40 on it, but again, I have it and it's free, so I'm using it...
Trying to skimp at this stage as some rather large items need to be purchased (including a car for me and a new refrigerator %))
Ratch
Looking good there. I just got my engine trans pulled out of the donor today. I am just starting mock up on my bronco so I am way behind you. Thanks for the info! subscribing to this thread for sure.:D
broncokak
Great info Steve. I want my 4R40W in before the Roundup...we'll see if that happens or not. One good this is I already have the ZF adapter! ;D
