"The Turd" build Thread...
sprdv1
REBEL
LOL, let's hope it was just the lead foot and a couple minor issues.. ;D
Mine wants you to use lots of skinny pedal as well..! Seems to be sputtering some at take off from idle speed... gotta look into that a little further.
broncokak
I avarages 14.2 on my trip to and from Gore. 123.57 Gallons of gas and 1760.5 miles total. I think I would have done better but I got some bad gas in Hazlton, PA on the way home the engine skipped like crazy and had no power on the hills. I stopped and got some dry gas and that helped a little. MPG after that fill up dropped to 12 MPG. Everything else was in the high 14s with a bet MPG of 15.4 on the drive down and the worst on 10 for two days on the trail. Having a lead foot doesn't help.%) I also leaned that sifting into OD to soon can kill the MPG. I have found I need to be above 2000 RPM (or 50PMH) or I'll suck down the gass.
76MaBronco
76MaBronco
Massachusetts
I was hoping for 15 plus...I know I have to tweak my shift points with the Baumann. I'm going into 4th with torque converter lock at 45 - which ends up being around 1200 rpm...WAY too low. I may have to regear too. 70 is 2,000 rpm...someday, I'm not really ready to worry about that right now. Maybe this winter I'll bring it up to Elias and have it done, but right now I'm enjoying bringing it to work and getting the thumbs up, second glances, and such...it's fun.;D
av8rds
MAhole!
2300 mi East of Moab
Jim Basal or Todd can do your gears. Don't bring it to a Heep guy!
broncokak
He built the axles I'm using...figured I'd just bring them back...I'm open to others doing it though...depends on time and cost...
You can do them yourself. The 9" is super easy because you can pull it out and work on it on the bench. Once you get that under your belt the D44 will not be very hard at all. What do you have for gears now? What size tires?
76MaBronco
76MaBronco
Massachusetts
I'd want someone with a little experience watching me on that job...I've never done them.
Right now I'm running 4.10's and 33's
broncokak
I'd go with 4.56 gears then.
Drive on up here and we can do them in a weekend.
Need to check the schedule before committing tho.
broncoitis
Hmm...that sounds like a camping trip opportunity ;)
Not to be rude but I wouldn't mind getting in on that if mine is up and running when you guys do that. Can never know too much and I keep missing all the darn events. ;D
There are signs of good things in the very near future. Truck moved on its own power today after sitting patientley for close to 10 years. You could say I am a bit happy tonight. :cool:;D:):D;)
76MaBronco
76MaBronco
Massachusetts
Time for an under dash harness I guess...let the smoke out of the wires on the way home...ignition portion is toasty and crispy...sitting on the hood, back on the windshield as I type...so much for taking it camping this weekend...
76MaBronco
76MaBronco
Massachusetts
No, not too bad...I went over some railroad tracks and the radio shut off for a second...thought that was odd...then went over another section of the same tracks and heard the smoke escaping out of the vinyl jacket...then I saw it...didn't scare me more than saying "aww shit, this is going to put a damper on the weekend"...
I'll tear it down tonight maybe...maybe not.
76MaBronco
76MaBronco
Massachusetts
Thank you...
It's home. The wire burned up 3.4 miles from home...AAA said no charge.
On a positive note, my bumper held up to winching the Turd up the ramp....
sprdv1
REBEL
No charge is good at least. It defintely coulda been worst buddy
broncokak
Ya I got it tucked to me by AAA once with my Bronco...Now I just call Todd ;D
Sorry to hear this Steve. Can the harness be reapaired or do you need a new one?
76MaBronco
76MaBronco
Massachusetts
It's just one wire from what I can see (with crispy bits of toasted vinyl falling in my face)...I think I can repair it, but I'm going to have to take a good portion of the harness out from under the dash.
I was all set to flat tow it to this weekends camping trip, but not now...The rush is on to register the dolly and tow the J33p instead. :-[ Not what I wanted to do, but at least it's open top...better than towing the minivan down...%)
