av8rds
MAhole!
Rear seatbelt clips...
Now see thats how I think it should look(not that I an expert on ANY level). When I think of stacked dimes I think of this stuff, which doesnt look consistent or even but yet people seem to love it.
I would add a small gusset to either the top or bottom to these brackets unless your guy was able to weld the backside as well. If they're only welded in the front, they could bend/break with the force of a crash or roll-over....
Just another opinion.
He wasn't. The head of the gun is too big to get inside. Good tip though. It's still at the shop, so it's an easy add-on.
Another issue is spring warp. I need to tame that issue fast as I'm collapsing the driveshaft completely with all the torque and flexy springs. Suggestions??
We use to add a spring clamp on the shortest spring....
You might try a heavy duty hose clamp to see if it helps?
Happen to have a picture of that set up you can post?
I'll make it at work, just looking at suggestions...saw a video on youboob over the weekend. Looked interesting enough...
I've seen that one before. I think I'd want a hiem on both ends (rebuildable) and less depended on the flex of the rubber. Would only need one, I'd think two would limit flex a little. But the kit has two...hmmmmmmmhttp://www.summitracing.com/parts/TFY-10997/
This is what I was talking about when suggesting making a link.
