"The Turd" build Thread...
76MaBronco
76MaBronco
Massachusetts
don't belive you.....drive up to me! ;D
Not in its current running form...just got back from a test drive. She's skipping. One cylinder isn't firing...don't know which one yet.
76MaBronco
76MaBronco
Massachusetts
WOOHOO!!!
Just got back from test drive #2 and WOW!!! What a difference in power using the '93 Mustang harness from the Explorer harness. It's a totally different truck now. SO much more power, it's unbelievable!! Wicked happy...wicked!!
broncokak
WOOHOO!!!
You think you like it now...just wait till you get it on the trail! ;D
76MaBronco
76MaBronco
Massachusetts
I had to put an extra spring on mine to make it feel right.
It feels okay, but the sensitivity is way too high. I need to bring the cable closer to the pivot point. It's too far out making the slightest movement look like I'm punching it. It would be scary if it were slippery.
broncoitis
If you are running the mustang throttle body, you have to make the pivot arm longer. I think that the kit from BC broncos come with a longer pivot arm as well. Did that with mine and it seems pretty good!
Awesome that you have it running! ;D
broncokak
Damn, I completely forgot about extending the arm on the throttle. I thought of you see cable and it came with the extension. It made a huge difference. After I extended it I had to put the extra spring on to get the feeling back.
76MaBronco
76MaBronco
Massachusetts
I'll have to order one up...I looked at modifying it but there isn't enough meat there...
broncokak
Your still using the explorer TB right? I'll have to take a look at mine but if I remember right I had to tig weld the new extension to the arm on the TB. I don't remember now why I couldn't bolt it together.
76MaBronco
76MaBronco
Massachusetts
Nope, Mustang...bolted right on. I did modify my gas pedal to use the cable. Heated it with a torch and twisted the end 90* and added a slot to slip the cable through, then closed it up. Works good...
use a garage door spring probably help with fuel mileage ;D
And the size of my thighs!!!
76MaBronco
76MaBronco
Massachusetts
Last night the Bronco was called into action...my oldest daughter (21) got her Subaru high centered on some snow. So I grabbed the chains and pulled her out. Somehow the starter died, so we had to pop start it to get it going. She jumped in the Bronco and I popped the clutch. By the time it was all over I had used everything. 2Hi, 4Low, 4Hi and back to 2Hi. My JB twin sticks worked awesome and I had a very thankful feeling I had time off between jobs to finish up the EFI swap...
tasker
all knowing of nothing
NH
very nice! have some weather this weekend that you can put some miles on too!
76MaBronco
76MaBronco
Massachusetts
Drove it to work all this week as the GF and I played car shuffle...looked down on Friday and saw 52,000 miles. Not bad seeing its 30 years old...
76MaBronco
76MaBronco
Massachusetts
I had some time to work on my bumpers this weekend because the kids are gone. Found a solution to the latching mechanism and painted it with a different color that I like better than the paint I used on the bumpers. So now I have to repaint the bumpers. :rolleyes:
