BG's 68 Bronco
- Nov 16, 2005
- 866
Alright I know do a search, but I read so much I can't think anymore. I've done both the chevy disk and h-boost. I'm having issues with very limited pedal pressure for the front brakes... meaning I have maybe 20% braking force coming from my front brakes. Rear brakes are working get... I can lock them up in a second with h-boost.
Anyway, I've bench bled the MC as per instructions and I know it isn't causing the problem because the MC did exactly what the instructions specified. I've bled the lines.. no air. Ground the knuckle down can't see it binding anywhere, as it has 1/4" or more clearance everywhere. I even watched the functioning of the calipers while a helper pushed the brake pedal down and no ballooning of brake lines either. Everything is working, but only at 20% on the front. There is nothing wrong with linkages etc under the dash good pedal travel and fluid motion but the pressure doesn't build up when stepping on the brakes until you hit the rear brakes. I have a corvette MC paired up w/ K5 blazer calipers.
One thing I have noticed is the stock brake lines, which connect to the MC are the same dia. and when you look at most other brake systems the brake line for the front is usually a larger dia. Could this be my problem, or have some of you with the same set up used the stock lines with no issues?
Thanks boys and girls![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
