SaddleUp
By all means correct me if I am wrong. Even better when you have documentation to support it which you have. I can't argue with the pictures you have displayed.Nobody said:I hate to call you on this, but it is absolutely wrong. Most of the Chevy's are opposite of ford, including the popular corvette master. This is why everyone is always having a problem with rear wheel lockup.
This is a good website for looking up master cylinder bore sizes. They also include pics of many of the parts. http://www.discountautoparts.com/
Just to pick at random, here is a '78 blazer 4x4, and a 76 camaro. Note the smaller reservoir is to the rear.
76 camaro
72Sport, even if the brakes are disk/disk the master cylinder should be hooked up in the right direction. The disks may not be the same size to start with (rear disks are often smaller than front ones) and even if they are not the front brakes still need to have the most braking power. I'll concede that GM couldn't make up their mind (I figured that as soon as I posted someone would prove me wrong) but they still should be mounted as designed.
FWIW, My disk/disk master cylinder doesn't have matching revervior sizes. They are both large for sure but the one closest to the firewall is still a little larger than the other.
