Third times a charm v3.0
JSmall
JSmall
Are you going to have to move your tank back? I have perches to go on mine but I have about and inch of clearance between tank and axle but I have a 23 gal tank.
I have the stock tank for now. It doesn't look like 1" will cause any clearance issues.
JSmall
JSmall
Made some progress
Crawdad
I like the look! Can you get a pic of the new perches and u-bolts installed?
JSmall
JSmall
I'll have a few pics tomorrow. I have everything tacked together right now and I'll be pulling the axle tomorrow to have it fully welded.
Krawlin5
you look like you have more rear clearance than I do. I have a 2'' body lift and what I think is a 2'' Duff suspension lift.I rub on the front edge of the rear fenders pretty good off road to the point it has pushed my fenders out some.
JSmall
JSmall
I'm not sure, but I have 9" between the frame and axle tube.
JSmall
JSmall
Finished other than bleeding the brakes. Thanks go out to Andrew for the welding help.
Blocks for now
Crawdad
Ok, so there is an extra hole one inch back from original hole in your spring plate, correct? I hate to bug ya for another pick but can you get one from the top of the spring perch showing where the holes line up? I'm starting to understand how this is coming together.
JSmall
JSmall
You are correct. I don't have a picture of them installed right now, but you can see them in this pic. The perches and top plates have three indexing holes. I'm using the forward most hole to push the axle back. I corrected my pinion angle at the same time.
Crawdad
I went to the previous page and saw that pic. Made a lot of sense now. What degree did you set your spring plates/ pinion angle to?
JSmall
JSmall
I set my pinion 3 degrees under my driveshaft. Sitting in my garage the DS is 20* and my pinion is 17*.
MyOriginal66
Looks good! Congrats on the 1000th!!! Now we just need some wide shots of the bronco with the axle relocation.
