Throttle Down Kustom Frame, issues
flexmerc
All,
I was going to wait till i finished the whole operation before posting infomation on the Throttle Down Kustom Frame, but that being said i ran into some crossroads, and I am looking for a way forward.
I purchased a Throttle Down Kustom Frame around August 2019, this year i have had alot of time at the house (global pandemic), so i decide to conduct the frame swap in my two car garage. (I will never do that again, ahah)...more on that later.
Problem at hand, is the preset and reinforced frame steering box holes do not line up with my steering box stock or aftermarket one purchased from WildHorses. The wildhorses steering box fit and worked flawlessly in my original frame.
https://www.wildhorses4x4.com/produ...ring_System_Deluxe/bronco_Power_Steering_Kits
What is the best way to drill new holes in the steering box to have them line up with my Frame holes?
rguest3
I have a TDK Frame for my 77 Coyote build.
The Factory 77 Box fits perfect with NO issues what so ever. The Borgeson box does not line up exactly, but it will fit with some minor grinding.
flexmerc
flexmerc
Have you called them and asked?
If so what did they tell you?
For me I would start by asking the vendor.
I just got off the phone, they suggested I call a parts store and see if the earlier steering box is different from my 74 model.
Kind of shit customer service in my opinion.
Stand by, I will double check my fitment with the stock and wild horses steering boxes, for a sanity check...
rguest3
The Steering box I see pictured in Post #1 looks like a Borgeson box.
The 76-77 Power Steering Box fits perfect on my TDK Frame and I would assume the 73-75 Power Steering box fits the same.
The Borgeson box I have does not fit out of the box. The top, left mount hole would need to be ground for proper clearance.
flexmerc
flexmerc
I checked the stock steering box, it's a closer fit, but the box is bumping up against the engine bay body, preventing the holes from lining up.
Looks like something im going to have to work through, one way or another.
Thanks for assist guys!
Jebus
Longview, WA
I wonder if the 4x4x2 box adapter plate can be used in reverse to what it was intended for?
flexmerc
flexmerc
Nothing about the 4x4x2 box or adapter plate will help with his situation.
Which leads to my first question, what's the best way to drill the borg steering box, A drill press?
Or cutting the rad core support for the original steering box, that sounds sketch.
tinytim02
Does your core support have the recessed panel for the power steering box? It doesn't look like it from the picture, but its hard to tell.
I've read that sometimes a PS box will fit, sometimes you need to cut the core support. Cutting the core support may be an option.
Jebus
Longview, WA
Ya, oops, I missed the later posts and was assuming the frame was already a 4x4x2 steering box bolt pattern.
unimogger
Philthadelphia
If you were going to modify the steering box, I'd use an end mill and do it with a vertical milling machine. A drill press is the wrong tool for the job. Or maybe a carbide burr in a die grinder; slow but would get the job done.
That said, I'd make the frame fit whatever steering box I intended to use if possible. Especially if I was using a stock bronco steering box, that way swapping to another box is just a matter of bolts and not doing this all over again.
rguest3
flexmerc - I'm just curious. Is your TDK frame factory width or 1" wider to each side?
They sell the wider one for the Coyote builds.
flexmerc
flexmerc
My frame is a standard width.
I guess it confuses me as to why the borg box fit my original 74 frame (which has the same holes) but won't fit the TDK frame which is designed for the original steering box.
I think it would be easier to mod the body or borg box vs the frame
Thanks again guys.
Jamie Chriss
I have the same frame, I am running BC F-150 4X4X2 Conversion it fits the bolt pattern.
Jaybr
I had the same problem with a new borg box on my stock 74 frame. The sloppy box I pulled off was also a borg box and the holes had been stretched a bit. I ended up using a carbide bit in a die grinder and extending the top right hole of the steering box enough to get them all in. I had a brand new bit and it only took a few minutes of grinding.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
4x4x2 does not fit the bolt pattern for a stock EB frame or stock EB steering box (power or manual). The bolt patterns are completely different and require new holes to be drilled or the WCB adapter plate. Again, the 4x4x2 will not help the OP with his issue.
