Throttle return spring
Tulsa76bronco
I am having problems finding the right spring. Going from the front of intake to the Holley TA carb. Most springs way too tight. It is 7.5 inches of space to span. Here are two I have tried. Having a hard time finding the right spring. Any suggestions or pics of what u have tried
Tulsa76bronco
Tulsa76bronco
Pic of the larger spring
Picture with too tight spring hard to push the throttle down giving me foot fatigue
707Bronk
You should be able to get a bracket and mount it under one of the intake bolts a little closer.
It looks like that spring is extending past the valve covers, and there should be a couple intake bolts you could mount the bracket with that are closer.
I have my spring mounted on the bottom of the linkage and streatched towards the firewall. But I have an edlebrock, not sure if its possible for holley linkage...
Tulsa76bronco
Tulsa76bronco
So as u can see I have a kick down bracket on the back side so it interferes with me running the spring that way. This is a Weiand intake and I don't see many other choices on putting the braket
Tulsa76bronco
Tulsa76bronco
As u can see I have a different spring on in the more recent picks it is just too light
jw0747
San Antonio, TX
most auto parts stores sell a package that includes springs of various sizes. try looking in the Help section.
707Bronk
Now I see what you're talking about.
Could get creative and make a bracket similar to what you have except extened closer to to reach the springs.
Or, order some new throttle linkage/brackets like nut73.
If you re-routed your existing cables you might gain enough room to fit the spring facing the rear, but Lokar is prob your best bet.
Tulsa76bronco
Tulsa76bronco
Nut I have looked on all three of those sites I can't find that bracket I apparently just don't know where to look
bronconut73
Google Lokar. The bracket on the carb is generic. Infact so is the cable. The kickdown cable has a C-4 specific bracket where the cable hooks to the tranny.
Summit, Jegs, Speedway all see the throttle cable and carb bracket with springs.
BC has it just as cheap. I'm looking now. Got mine from either BC or JBG.
11-71020 at BC.
