TIG welding door frame posts
bronco_daddy
Paso Robles, CA
I have a seen little bit of posting on this. Our '73 has cracks at the base of the door frame where it meets the top of the door. The paint on this truck is cherry, I really do not want the outside paint damaged, inside I can accept. I am having professional fabricator for rock crawlers, etc doing the welding tomorrow....I really need some tips here to pass along if needed.
The frames are covered with the factory aluminum covers... freaking nervous over this.
NicksTrix
well some paint is going to have to come off to weld it up. even welding and quick cooling the heat is going to want to make some of surrounding paint want to lift.
it's just paint. a touch up can easily burned in by a good bodyguy. we do it all the time.
trailpsycho
A buddy of mine TIGed them 360...this was2 years after the frame off. Sucked, but loose rattling door frames on an otherwise "frame-off" project...well thats just too much for a man to take. My paint shop reshot the doors, no problem.
trailpsycho
A buddy of mine TIGed them 360...this was2 years after the frame off. Sucked, but loose rattling door frames on an otherwise "frame-off" project...well thats just too much for a man to take. Make sure you remove the glass, vent window frames, trim and other door stuff prior to him beginning his work on it. You will need to do so anyway to check the extent of the damage. Make sure you look closely, there may be additional cracking and you wont be able to tell without tearing it all the way down.
Good luck!
bronco_daddy
bronco_daddy
Paso Robles, CA
So today I took it to a young guy (early 20s) that I was told to be the best there is...literally born with a TIG welder in his hands. Entered his shop and was stunned at the fabricating craftsmanship in the off-road race trucks he was building. Artisan to say the least. makes his own rear ends, trailing arms, frames...everything.
6 hours later I get the call, the EB is ready. Arrive and he is all smiles as he greats my son and I. Outside door paint perfection, not a mark. Aluminum door frame covers...not a mark. Brand new door felts...not a mark or burn.
Ground out all the old crap, built up with the TIG to bring everything flush. Ground it down..then bronze filled any imperfections, ground that down flush and finished sand to paint ready. I have maybe 1/2" of paint to touch up at each post in the jambs which was glossy black...frames are STRONG! I was so worried about the exterior paint and I am so very pleased...rare you get more than you ever imagined in quality.
$200...that was it..the kid rocks. Gives me high hopes in the youth of today.
Bluesclues73
Haha, not all of us younger guys are so bad! Just a few loudmouths out there that give everyone a bad impression %) There's definitely some talent here in so cal when it comes to off road! I have a close friend/old co worker thats the same way, he's been putting out some amazing work for various off road teams as well as on his personal projects. He's in Simi area though, mind me asking where/who you took yours too for future reference? Also, post up a couple pictures if you could! thanks!
- Eddie
There are only young good welders by the time your in your mid 40's your eyes get so bad you can't see to do the small precision stuff any more. Stick and mig welding the big stuff you can still do. These off road fabricators are spending day in and day out with tig welding laying miles of beads. It amazes me how much welding they do these days.
Madgyver
Bronco Madman
Please post pics......
You say the cracks were inside the door jamb?
lowbush
Summerland Key, FL
I have not quite hit 40 close enough though, but I TIG everything. I find it easier to weld with a TIG, I get a cleaner weld, and I am 100% sure of the weld. I like the fact that TIG is pretty much you got a full weld or you can tell. With the Chinese welders the cost of a DC TIG / Plasma has really come down to the hobbyist price range. I just wish the AC boxes would so I could TIG aluminum. I still have to Stick that stuff together on a DC box and Stick is an art that I have far from mastered for sure.
