timing chain deflection
Madgyver
Bronco Madman
Pete Jackson Part #289-9C
;D ;)
The part# of the double roller I didn't use is AVON #114
ballistic64
Piedmont , SD
Comp Cams #2120 is a double roller that should fit with no modifications,I know its avail. from Summit for about $40.00.
I went with Comp on my 70' 351W rebuild and had a hell of a time getting one locally.They kept giving me one for a late model that uses a 2 pc. ecentric.Finally got it from Summit (where I should've in the first place).
Madgyver
Bronco Madman
That big round thing that is off-centered on the big gear is the eccentric for the fuel pump lever. if it has an outer piece the spins on the inner piece it is a two piece eccentric.
Go with a quiet gear drive if you could afford it. I really like mine now... Piece of mind. I know now that if something goes wrong it's not the cam timing. Very big difference to what I've been driving this past year or so. Cam timing on my DD may have been off for awhile before the change.
mitzel
Googleplex
ballistic64
the associated footnote says ``Can be used on late model engines but requires
one-piece fuel pump eccentric''. the #2138 double roller listed for '84-'92 engines
is the only one to explicitly say it accommodates a two-piece eccentric. I have no
idea if that'd be compatible with a '76 engine; anyone know what changed in those
years related to timing chain&sprokets?
from comp cams your only choice for a direct bolt on, no modifications appear to be #3230.
that's a non-roller/OEM style.
Jeepster
> I take it that this is a two piece eccentric, right?
yes.
antnykk
Northern New Jersey
I am real curious about the gear drive. I am going to replace my set soon and was orignially going to go with the double roller, but now considering the gear drive.
Any opinions from current users?
What are the advatages?
Madgyver
Bronco Madman
Jeepster said:
Then again maybe just slap a OEM chain on it and forget it. Sometimes I think too much.%)
Dan
Dan,
This was my thought the first time I changed the timing chain on the EB and so I did throw in a stock replacement and forgot about it.
Now I realized that it was the cause of most of the engine problems I had to date, Thinking that at a little over 30k miles on this stock replacement chain it wouldn't of stretched so much, I was WRONG.
My advice would be to go with a quality double roller set or a quiet gear drive. I prefer the gear drive. After installing the gear drive I now don't have to worry or quess if the cam timing is off. I would never jump a tooth like the chain does as it gets worn.
Installing the gear drive is simple with basic tools and some cutting/grinding on the aluminum timing cover.
Thinking too much is good just don't spend too much time doing it......;D
Honorio
mitzel
Googleplex
Jeepster
> Being a 76 (actually 74, D4 stamped on the block)
all '76 302 should be a D4DE-AA or D5ZY-AA block casting, so yours seems reasonable.
ballistic64
> I didnt think they started using the 2 pc eccentrics until the 80s on the SBFs?
I believe the change over for 2pc eccentric is listed as 5-2-72.
back to the timing set selection I can say in my limited experience logging
300K+ miles on my various 289&302 the only option I would absolutely rule out is buying
a replacement OEM silent timing set. that's what came from the factory and they use
a nylon camshaft sprocket, which tend to disintegrate quickly. all of the various
OEM-style chain that come with a cast iron sprocket (like the comp cams #3230)
should easily provide 100K+ miles of trouble free service. and for a performance buildup
or even more reliability the double roller chains are excellent.
I have no experience with the timnig gears. I guess if they're now making sets that don't
have that annoying whine they may be worth considering. if you do a search of various
automotive and engine forums you'll likely find roughly even number of people claiming
they're great and an equal number of people saying they introduce numerous problems.
66horse
Jeepster said:
any body have any other part # that they have installed? I need to buy and get this done.
Dan
Jeepster,
Here is an idea. Call the Ford Motorsports/Racing? tech line. I hear they are real helpful. Alternatively, call Summit and tell them what ou want, what you are worried about, etc... and possibly order from them.
broncotime
Grapevine, Texas
I just bought a brand new timing chain cover for my stock 302 from driven auto parts for $65. It is brand new and he has lots of them.
I can't remember the web address, but do a google search for "driven auto parts" he is in Arizona and has a lot of wrecked EBs that he parts out. He also sells new bronco goodies via his web site and on eBay. I just bought a pair of really heavy duty motor mounts from him for $99. Just as beefy as the WH ones but cheaper.
md_lucky_13
Idaho
I don't know if you are still interested in this..
But I can have a bunch of info up in about 2 hours, with all kinds of pictures...
I got a Cloyes chain from Jegs:
220-9-3135
Ford V8 221/225/260/289-std/302-std/351W-std, 1962-84 (3/21/84)
$77.99
and you think that deflection is bad?? Mine was so worn out I could just about wrap the chain around the bottem sprocket. I will have a few pictures up of that, also.
Let me know if you are interested, and I will pull them up for you!
md_lucky_13
Idaho
Okay..
Here are a few pictures:
This is one with the old chain just in place, with no tension on it.
md_lucky_13
Idaho
Here is the old chain with tension on it:
md_lucky_13
Idaho
I am running an electric fuel pump, so I have no idea what (if anything?) would change if you needed to run a mechanical one. From what I understand, a mechanical pump runs off the cam, and would not have to change anything if you change just the timing chain.
I did not have to change anything. My cam-blocking plate (I don't know what else to call it?) was worn out, so I replaced that. I didn't have to change anything else. The timing chain cover was in great shape, and I didn't have to change that.
md_lucky_13
Idaho
I screwed up the first picture.. Here it is. This is the old chain with no tension on it:
