smokinjoe
I'm having some timing issues I think. A while back I was running down some overheating issues, figured that out (and you wouldn't believe what I did!!!!) and then the rig started running terrible, brought it home and thought my fuel pump was dying as the truck acted like it was running outta gas and then eventually did, long story short ran the aux tank dry like a jacka**, thought I was running off the main. Replaced the fuel filter, rebuilt the Edlebrock 4 barrel, messed up and ran it w/ the choke closed, fouled the plugs DOH! Put some new plugs in.
Removed the #1 plug, placed my thumb over the hole and bumped it until my finger blew off, check the timing marks and I was right around the timing pointer, pulled the HEI cap and was pointing at #1, sounds good right? Switched over the main tank w/ fresh gas and I can now not get this guy started until I advance the ever loving s*** outta it (for instance my hei wires are pointed at my steering box and I have to advance all the way to the thermostat housing), but it's still not running right at that point, will only stay running w/ gas pedal pressed and it's running slow like not enough advance. I will say that when I was tracing down my overheating problem I checked my timing and I wasn't even on the marks using the 2 o'clock pointer.
My EB is a 76, but at some point a PO dropped in a 351W (a selling point to me when I bought it). According to the castings it came from a full size 72 Ford car (D2AE-60 ......) At the parts store I have them pull parts from a 72 351W Galaxy 500.
Here's what I'm thinking, the PO who did the swap used all 76 302 front dress, would the 72 351 be a 10 o'clock pointer v. the current 2 o'clock I have?
If I bring it to TDC at the 2 o'clock pointer at restab the dizzy and then point it at #1 it shouldn't matter right?
Thoughts?
I believe they used the 76 302 front end accessories when they did the swap (after initially buying the wrong waterpump) and maybe stabbed it using the 10 o'clock pointer then bolted up the 2 o'clock pointer, make sense?
Thoughts?
