Timing problems - Wrong timing chain?! (Boss 302)
bsquared
Trying to help a buddy troubleshoot is 68 289 rebuild. It will run, but very badly and very rich. Somewhere around 34deg
Looks like he purchased a Ford Racing timing chain set meant for a 69 - 70 Boss 302.
http://www.summitracing.com/parts/fms-m-6268-a302
Question is, would a Boss 302 timing set work on a regular 289 / 302, so long as the camshaft is correct for this engine? Pulling the front and timing cover anyway to get a look. Appreciate any feedback.
Bronco73
Cape Coral, FL
I don't see why it wouldn't work. The only thing that may be different is the initial timing set by the gears them selves. Have you tried getting it to run by ear and not a timing gun? Is the firing order correct for the cam he has?
jckkys
Summit's application list includes pretty much all small blocks. The 10 key ways in the crank sprocket could cause some confusion in picking the right one.
broncnaz
X3 Im reasonabley sure there is no differance in the boss 302vs a 289 or 302 firing order really the only differance is the heads and pistons. Of course its almost 1 am on a friday night. I would suspect a slipeed balancer or a vacuum leak.
bsquared
bsquared
Thanks guys!
Yes, tried to run by ear...will only run at approx 34 deg BTDC and that scale moves up as rpms do. Have to agree with Jckkys...the 10 keyways very well could be the problem. The Boss did have a different firing order, but have double checked the cam and it's accurate for this 289, so firing order hasn't changed. If, once we open it up, the marks on the sprockets are not way off, then it HAS to be a slipped balancer as Bronconaz points out.
Many thanks for chiming back in for me. Will respond once we find the gremlins!
bsquared
bsquared
Update,
Pulled timing cover and all is lined up correct. Ran the valves a few times and pretty confident cam and valves are in correct firing order and operation.
I'm thinking it has to be a slipped damper. It's all that's left to change out so we got one on order. Get new gaskets and button it back up, bolt on a new damper and we'll know.
bsquared
bsquared
Yes, Fairlane, that's what I've been finding out, which takes other problems out of play.
I'm thinking the damper is all that's left. If that doesn't get it I guess I have to sell my Bronco, cause I'm sucking at fixing someone else's! I appreciate the input. Will post what results we get. B2
Boss 302 firing order is the same as a 289 or non H.O 302.
Bronco73
Cape Coral, FL
You say rebuild, how where the valves adjusted? They may be to tight. If a bigger cam was installed with heavier valve springs the rocker studs may be pulling out of the head.
ntsqd
heratic car camper
Upper SoKA
I dimly recall that the timing sets for the Boss 302 specifically did have a subtle difference from standard timing sets. Ganahal's Ford Performance book doesn't mention it, but I recall when I crewed on the Titan Speed Boss 302 powered R.E.D. that the owner made a comment about it being slightly different. What I'm dimly recalling is that there is a difference in the thickness or one or the other gears. I *think* that it was the crank gear and I *think* that it was thinner because the Boss 302 balancer had a longer snout.
