Timing problems
Vincen
I am having trouble starting my 70. It ran fine in late November and does nothing but crank now. I installed a Pertronix distributor, coil, battery and relay, carburetor and it still won't fire. I poured gas directly in the carb and noticed today the rotor is changing positions from my original firing order. I re installed the distr. and then checked spark to all plugs and have spark.
Any ideas?
jckkys
The distributor gear could be off by 180 degrees or one full turn of the crank and still be pointing to the correct cylinder. Pull the #1 spark plug and stick your finger in the hole to see if air comes out as the rotor approaches the #1 position.
