Timken set 20 axle bearing install ?
latrucker
When installing some Timken set 20 bearings, do I install the bearing race first then the axle with bearing and seal. Or do I install as one unit (race, bearing and seal) by tapping the axle to set into the axle housing?
Yeller
Rogers County Oklahoma
I assemble them as a unit, they should easily tap in. I put a bit of RTV or Hylomar Blue around the outside of the rubber part of the seal to prevent a leak.
latrucker
latrucker
Thank you!
