Timken wheel bearings
johnbeck
I have inner and outer wheel bearings for my disc conversion on my 1973 bronco. The numbers on the Timken boxes are LM603049 and LM501349. I want to buy both as spares. On Amazon they list the same numbers but with additional numbers attached. Are they listing those additional numbers because they come with racers or what? Thanks
needsmoarturbo
Depends, the additional numbers are probably cones, but don't know without the exact numbers. Google is your friend.
Usually that is correct. So if the numbers are for instance, LM603049/LM603011 then those are cone/cup bearing/race combinations.
Apogee
Cups and cones. You may as well carry a full set, as it doesn't take any additional space and if you trash a bearing somewhere, odds are the race and bearing need replacement. I've always had the misfortune of trashing the spindle and/or hub at the same time, so you're best bet to avoid ever needing a spare bearing is good preventative maintenance and quality wheel bearing grease IMO.
...I've always had the misfortune of trashing the spindle and/or hub at the same time, so you're best bet to avoid ever needing a spare bearing is good preventative maintenance and quality wheel bearing grease IMO.
True words there!
And proper initial adjustment is often the key.
So if you're not sure about the correct procedure that's, as far as I know, relatively unique to the Dana 4wd axles, just ask. It's in the book too if you have a manual. Easy to do after the first time, but seems silly the first time you try it if you've spent much time adjusting old car wheel bearings.
