Tips and tricks for head gasket replacement
rylsky
Southern CA/NV
So I am goona replace my head gaskets soon. I did a SBC 20+ years ago when there was such a thing as "Auto Shop" in high school. I have tools and I have the Chilton manual.
I would appriciate and tips and tricks to make it a little easier. I could also use some hands on help if anyone is interested. I am sorta not in a good place to work on my Bronco and will need to take it elsewhere. If you happen to have a space and a few spare hours and like beer and U.S. legal tender for advisory services let me know.
I want to do it myself but I also want to be able to drive it the same day. Not always happens when I try new things. I am getting another set of heads on Sunday at the Shelter Island deal and will use them. My old ones were pretty worn. Screwy thing is a few weeks ago I worked a deal for the heads. Figured I would take them to my head porting class I was gonna take next summer at the local college.
So now I hope to change the heads and gaskets. I hope to not only solve my current un-drivable condition, but that my old heads were the cause of my oil burn. I will be dropping my oil pan tomorrow and checking the main and rod clearances.
So anyone in SoCal like cash, beer and have some space for a feew hours?
I am near San Dimas 91773 but have AAA 100 mile tow. I dare not run it anymore: It is bubbling out of the overflow.
Let know and lets talk.
Thanks!
G
bronco at rylsky dot info
68 Broncoholic
WA
Beer! Wish I could its a quick change out. Keep the carb connected to the intake, unbolt the intake, disconnect the throttle linkage, air hoses but keep the gas line on of its long enough to rest the intake on the top of fire wall. Disconnect anything else that will hold it up from pulling it off. Unbolt the exhaust manifolds or headers and leave them there. Pull the heads and replace everything.
Skipdevil
San Diego
I just did a top end rebuild on my 302. It is really easy to change out the gaskets yourself. Before removing your heads perform a compression and leak down test in each cyllinder using your Chilton book directions. This way you can see if you have a bad piston. With the heads off take a good look at the cyllinder walls for scratches and scoring. If the walls are nice and smooth then most likely the piston rings are ok. A few days prior give the heads a nice coat of high temp Ford Blue on the outside parts. Make sure you carefully and completely scrape off ALL the old gasket materal so you get a good seal. Get the good Fel Pro head and intake gaskets. No RTV on the head gaskets. Go to Sears and get a torque wrench in Ft Lbs. When you put the heads back on follow the EXACT tightning sequence in the Chilton book. Just make sure that you pay close attention to the disassembally of the parts and organize all the hardware in zip lock bags.
If the car is drivable I would be happy to help but I live in San Diego so it may not be worth the drive. Personally I think you can do it yourself in a day.
Skipdevil
braxton357
morganton NC
Use the fel pro 8548 pt2 head gaskets, fel pro calls them "stock replacement" but they're actually stronger than the fel pro "performance" gaskets for sbf's, and they're cheaper. Clean the whole engine bay first and everything will be easier, but as long as you have the head already put together..it's a simple and relatively quick job...just go by the torque specs in your chiltons.
